Is my cpu getting to hot my cpu fan runs in high speed a lot. do i need a bigger fan or my cpu is going bad.
    Sniper:
  • 66 Answers
The most common reason your fan would start spinning in high speed is that your CPU is overheating.
Usual remedy is to reapply the thermal paste on the CPU.
Click here for instructions if needed.
Posted on Nov 17, 2009
    Brigadier General:
  • 10,406 Answers
Neither.
Turn the computer off.
If it is a HP laptop, remove the battery.
Disconnect the AC power.
Buy a can of compressed air, and give your computer a "blow-job",
to blow all the dust away from the heat-sink on top of the CPU,
and also, if it is a desktop, from inside the power-supply.
A layer of dust is a layer of insulation, preventing the heat-sink on top of the CPU from "radiating" the heat away from the CPU. So, your motherboard is detecting that your CPU is "too hot", and automatically speeds-up the cooling fan, to try to move the heat.
About my dell desktop?
If it gets hot, fan will speed up. If it's getting hot, possibly the silicone grease between the heat sink and the CPU is dried up, or else you have poor contact. (Loose snap-down hardware)
Fix it soon, or Bye bye CPU.
Nov 05, 2014 | Computers & Internet
Fan problem
The reason for the high fan noise is that the CPU is starving for cool air and is getting too hot. You should blow the dust out from the fan area as best you can with compressed air. Another option is that the laptop may be too close to the surface and can't breathe, try raising it off the surface and see if that helps. One more possibility is that the fan's bearings are going bad and the fan needs to be replaced. There are some programs (not to forget a possible BIOS feature) that allow you to control the fan's speed. Try going to hp's website for your laptop and see if there is one.
Good Luck!
Rich Lilja
Jun 28, 2014 | HP Pavilion Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
Fan runs at very high speed
Hello
OK, firstly, if the CPU fan runs at high revolutions, it means that the CPU is very hot. The more heat on the CPU, the faster the fan will run in order to keep the CPU at the safe temp.
Hence, you will have to open up the case and have a look if the CPU fan housing is clogged with dust particles, this is usually the most common cause for the CPU to overheat. If you can see that there is a lot of use stuck to the fan, you will need to blow if off, i use a compressed air cylinder, it works great.
If there is no dust particles visible, you will need to put some new thermal paste on the CPU chip itself.
Try the first option, let me know what happens.
Kind regards
Andrea
Aug 13, 2010 | HP Desktop Computers - Hewlett-Packard...
Latitude D600 PC Notebook: Installed new RAM 1G on Dell Lat600,Now CPU is run...
It is not the memory causing the issue. You either have a clogged fan and heat sink or a bad fan. This will solve most heat issues with the laptop.http://www.diefer.de/i8kfan/faq.html
Install this software and put the fan on manual high. That should help a lot if the fan is still working.
May 18, 2010 | Dell Latitude D600 Notebook
G4 12 inch powerbook
Sounds like your machine is overheating big time. You didnt say if it boots up or not, but I wouldnt keep trying until someone can look at it. You probably need a new fan, possibly hard drive, hopefully not mother board.
Jul 30, 2009 | Apple PowerBook G4 Mac Notebook
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
COOLING FAN AND COMPUTER CUTTING OFF
When you say cut off are you meaning that the laptop is shutting down?
The fan is only running intermitently when on battery as the laptop is running in power saving mode
and the speed drops when not needed as well as the cpu voltage
therefore reducing the heat produced and the nedd for the fan to run.
Try using a program called cpu-z and it will show the speed of the cpu going up and down as needed. Also use speedfan to sjow you the cpu tempreture.
Hope this helps and puts your mind to rest ? :)
Dec 29, 2007 | Toshiba Satellite A25-S207 Notebook
121 people viewed this question
k24674
jasbo
jasbo
