Question about KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
I did a self clean on the oven, after an hour the oven shut off and door kept locked, the control panel went blank. What part(s) do i need to replace?
Please help
  • 1 more comment
  • jasminsnocon Jan 10, 2008
    i already checked panel breaker and its fine... Oven still not working.
  • Anonymous Jan 18, 2008
    I have a kitchenaid superba oven that is giving me a FE:E0 reading. The oven won't work now. Can I fix this?
    Thanks
  • marlene7653 Jul 27, 2008
    I was doing the self cleaning for the ovens when it was done the oven shut down and now nothing works for the oven and the doors remain close. I too have checked the brakers and they are fine. Help!
  • 319 Answers
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Posted on Jan 10, 2008
  • Brian Berndt
    Brian Berndt Jan 11, 2008
    I don't know how old your oven is, but there is a known issue with KitchenAid and Whirpool ovens. I have attached several links that discuss some of this problem.
    What has most likely happened is that the internal fuse has blown. See here.
    Discussion about similar problems here.
    Upset consumers vent frustrations here.
    It looks like a service tech will need to fix this problem for you.
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Apr 19, 2013 | Electrolux Kitchen Ranges
I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
Feb 03, 2018 | Frigidaire Ovens
Fan stuck on, door locked
Hello,"If actual over temperature condition occurred"
Look for welded relay contacts. If this happens,replace oven control (also called clock or ERC).
IF NO OVER TEMPERATURE condition occurred: Look for high resistance connection or any other cause of high resistance in the oven temperature sensor circuit.Check sensor, sensor harness and sensor harness connection at sensor and oven control .Replace sensor if found defective.Check door lock switches.
REMEMBER: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Thanks
Jun 01, 2010 | GE Profile JTP95 Electric Single Oven
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Self cleaning oven not working right
shut the power off and see if it resets.
Jan 09, 2008 | Ovens
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
KitchenAid KGRI801PBS Gas Kitchen Range Logo
347 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
