Question about Compaq Computers & Internet
I think my video card has faulty memory. How do I know for shur
I think my video card has faulty memory. I do I know for shur?
    Novelist:
  • 138 Answers
Passmark has a program that will test the system and video card memory.
http://www.passmark.com/products/pt.htm
Posted on Nov 18, 2009
Nv7 133r motherboard will not boot unless switched off and disconnected from mains for several hours. will only give single longer than normal beep, no video, beeps every 5 seconds
If you have multiple RAM sticks on your board, try to remove some of them and interchange, to rule out a faulty memory.
If you have an on board video card, remove any video extension cards and connect your monitor to the on board video card to rule out that as the problem maker.
If you have any other extension cards, remove them as well.
If all of that does not help, then there is either a problem with the processor or the motherboard itself, that is probably not possible to fix.
One more think I could think of is a faulty power supply. If you can get another one, try it with that.
Good luck
Hope this helps.
May 10, 2011 | Abit NV7-133R Motherboard
When turning power on it says SD/TF card error on my nintendo DS
The DS is telling you that the SD Memory card is faulty. Or at least thats what it "Thinks".
Feb 05, 2010 | Nintendo DS Console
When I power up my T5086 RA, I get three beeps and no video signal at all, even with a PCI-E video card. Help!!!
Sounds like memory problem.
Remove the memory modules and then insert one, and try to reboot. Do this until you find the faulty memory.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Computers & Internet
How do I insert memory card into nintendo 64? bought used unit for grandson and was thinking of getting a memory card becuase it seems it supposed to have one I bought a used donkey kongN64 and now it says...
The memory card plugs into the back of the controller.. i believe. No you do not need a memory card to play games, but you want one if you want to save your progress in games. Without a memory card to save progress, you will have to start a game over everytime you want to play it.
I am sorry I don't know what the expansoin pack is.... maybe a memory card, or rumble pack.
Sep 16, 2009 | Nintendo Memory Card for 64
LOST PICTURE ON FLAT SCREEN
If you buy new PCI video card there is alway CD software attached on this,you should claim for this because it was the driver for your new video card ,without it your PC will have an abrormal operation .Are you sure it was your video card?you can consider also your memory card,Wiht out hardisk,CD room,floopy your computer will run it can open your monitor configuring the cmos and bios.Try on this one disconnect hardisk,cd room,floopy then detouched your memory card clean using pencil eraser the sloted terminal of your memory card,also your video card try to clean terminal by pencil eraser.Then put back memory and video card again if the monitor work.If ok put back again the cdroom,hardisk, and floopy.If not ok Isolate checking the memory and video card also the processor.
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
LG Viewty (KU990) Memory Card Issue
The default setting for the viewty camera is set as the handset. changing the primary storage setting to external memory does not change this.`Switch the camera on as if you were going to take a picture. Click on the cog wheel in the bottom left hand corner. click on the memory card icon (second to last icon on the left.) Top right will show memory in use. Select external memory and click the save icon below. follow the same process for the video camera. Pics and vids shoild now be saved on your memory card. If you take the memory card out you will have this process again.
Jan 13, 2009 | LG KU990 Viewty
Xbox 360 Not Reading 512MB Microsoft Memory Card
make sure it is fully plugged in and go into settings and then memory and make sure it pops up and then select it if not maybe halo needs a hard drive but i dont think but if it doesnt pop up in memory then its probably a faulty memory stick
please rate well
Jan 06, 2009 | Microsoft Xbox 360 Console
Monitor not on but menu light are blinking
Hi there, i assume you switch on the monitor but there's no display. Is the monitor working before this? If what i assume is right, you should check the connection between the monitor and the cpu. If that doesn't solve the problem, then you should check the vga card. Maybe the pci slot/vga port is damage. If that the problem, you should change another display card.
Dec 20, 2008 | Computers & Internet
How much ram?
Hi griff22_petm,
It is not you. The Biostar uses an intergrated graphic card. In your manual on page 2-13 & 2-14. Advanced Chipset Features.
You can set the total amount of system memory for the graphics card to use. Currently you have the bios set to use 8Mb of system memory to run your graphics card. (A wee bit low). If you need the manual you can download it from Biostar at this link:
http://www.biostar.com.tw/app/en-us/mb/content.php?S_ID=154
There is one other way to use all your system memory & that would be to buy a PCI video card, this would free up all your memory. Suggested PCI graphics card:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards&
Good luck griff22_petm!
Mike
Dec 03, 2008 | Biostar M6VLQ Motherboard
Unprotect memory card
To set the memory card in unprotected mode, you have to do the following.
On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
This unprotects the card. You should now be able to take pictures and videos.
If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
~Lexar SD card
~1 Panasonic SD card
~2 Panasonic SD card
~Sandisk SD card
Jul 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Computers & Internet Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
