Question about Dell Optiplex GX280 (99301) Motherboard
I have several Optiplex gx280 systems with the following error: fails memory diags, says there is a problem with the circuitry near DIMM 3, replaced memory, problem still exists. Filled up all memory slots, ran diags, problem still exists. Could there be a problem with the bottom of the caps being bad, instead of the tops being blown off?
    Genius:
  • Dell Master
  • 1,274 Answers
It's a possibility, does it happen regardless of what dimm you have the ram installed? you could just bypass that Dimm if it only fails on one.
Posted on Nov 17, 2009
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
Sir i have dell GX280 system 3.0 GHz optiplex. 1gb ddr2 ram with 80gb sata hard drive. Sir, my problem is this first i brought a system it runs fine but sometimes a day it hangs up. i return this...
Plz check your memory with memtest. It can be downloaded from http://www.memtest.org/download/4.10/memtest86+-4.10.iso.zip .
Unzip the downloaded file and burn the ISO file to a CD and boot your system from the CD. It will check the memory of your system and it will indicate any error replace the memory.
Also check your memory slot is clean .. you can clean your system memory slot using a anti-static brush (you can use a tooth brush if anti-static is not available) and IPA
Sep 12, 2010 | Dell Optiplex GX280 (99301) Motherboard
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
Dell Optiplex 725 Beeps at me at me at start up w/o complete start up. Screen Black. As if something is loose? Battery in Motherboard? Did something short out?
POST Beep Codes: OptiPlex GXi If the monitor cannot display error messages during the POST, the system may emit a series of beeps that identifies the problem or that can help you identify a faulty component or assembly. The following table lists the beep codes that may be generated during the POST. Most beep codes indicate a fatal error that prevents the system from completing the boot routine until the indicated condition is corrected.
Beep Code Error Probable Causes 1-3 Monitor not detected Disconnected or faulty monitor 1-1-3 NVRAM write/read failure Defective system board 1-1-4 BIOS checksum failure Faulty BIOS or defective system board 1-2-1 Programmable interval-timer failure Defective system board 1-2-2 DMA initialization failure Defective system board 1-2-3 DMA page register write/read failure Defective system board 1-3-1 Main-memory refresh verification failure Faulty or improperly seated DIMM or defective system board 1-3-2 No memory installed No memory installed or faulty or improperly seated DIMM 1-3-3 Chip or data line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-3-4 Odd/even logic failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-1 Address line failure in the first 64 KB of main memory Faulty or improperly seated DIMM 1-4-2 Parity failure in the first 64 KB of main memory Faulty or improperly seated DIMM 2-1-1 through 2-4-4 Bit failure in the first 64 KB of main memory Faulty or improperly seated DIMM 3-1-1 Slave DMA-register failure Defective system board 3-1-2 Master DMA-register failure Defective system board 3-1-3 Master interrupt-mask register failure Defective system board 3-1-4 Slave interrupt-mask register failure Defective system board 3-2-4 Keyboard-controller test failure Faulty keyboard controller (defective system board) 3-3-4 Screen initialization failure Faulty video subsystem (defective system board) 3-4-1 Screen-retrace test failure Faulty video subsystem (defective system board) 3-4-2 Search for video ROM failed Faulty video subsystem (defective system board) 4-2-1 No timer tick Defective system board 4-2-2 Shutdown failure Defective system board 4-2-3 Gate A20 failure Defective system board 4-2-4 Unexpected interrupt in protected mode Defective system board 4-3-1 Memory failure above address 0FFFFh Faulty or improperly seated DIMM 4-3-3 Timer-chip counter 2 failure Defective system board 4-3-4 Time-of-day clock stopped Bad battery or defective system board 4-4-1 Serial-port test failure Faulty I/O chip (defective system board) 4-4-2 Parallel-port test failure Faulty I/O chip (defective system board) 4-4-3 Math coprocessor failure Faulty microprocessor chip or system board 4-4-4 Cache test failure Defective microprocessor or system board
Mar 30, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Hi Iwill be glad to assist you:
Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Nov 05, 2009 | HP Color LaserJet 3500 Printer
Dell GX150 beeps 5 times on startup.
This normally means there is a memory error. Have you recently added memory to the sytem? You can try to remove and reseat all memory modules in the system to see if that clears the problem.
Jul 10, 2009 | Dell Optiplex GX280 (99301) Motherboard
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Dell optiplex 280 ddr2 memory information
You cannot use drr667 on this computer since it only supportr ddr533, and it will be better if you use one stick of 1GIG RAM since your motherboard supports up to 2 GIG of RAM...
Dec 02, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
