Question about GE GSS25JFM Side by Side Refrigerator
How to remove freezer door in order to replace ice dispensor plunger and solenoid
  • 4,070 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Nov 17, 2009
Our automatic ice dispenser hums but doesn't move ice through to be dispensed
Resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
The chute for the ice despenser is freezing up and nothing will come out of the chute because it is frozen solid
You should remove the freezer upper door hinge cover , and disconnect the plug there . This removes power to the door .
Remove the dispensor board , by prying out from the bottom . After removing the board , disconnect the 3 plug-ins on the board itself .
Remove the 4 screws on the white dispensor cover , and slide out the cover .
At the top right , you will see a solenoid with a plunger which the door flap rocker , slips into . Usually , this plunger will rust , keeping the door flap from closing completely , therefore causing frost in the shoot where the ice comes out . 3 screws hold this solenoid and plunger in place . Part number for solenoid and plunger is WR62X10055 .
You cannot remove and clean , due to the rust already starting . It will happen again , unless you replace these parts .
To disconnect the flap , raise the flap and the plunger will slide off .
Re assemble in the reverse order .
Oct 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Oct 10, 2009 | GE Refrigerators
How do gain access to the spring reces door that stops the ice from comin out.It is stuck in the up position
The control board on the freezer door , pops off from the bottom . May have to use a small screwdriver , prying outward , from the bottom . Remove the 3 plugs from the board . Remove the 4 screws , holdint the dispensor cover and slide the cover out . In the top right , in the dispensor area , you will see a solenoid with a plunger , which the door flap hooks into . 3 screws hold the solenoid on . Usually , rust inhibits the movement of the plunger , inside the solenoid . Replace the solenoid and plunger ( they come togather ) as cleaning will not solve the problem . Pt # WR62X10055 is the part(s) you need .
Oct 03, 2009 | GE Refrigerators
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice shoot leaks water into the exterior tray
It sounds like the dispensor flap , is not closing , letting warm air into the freezer . Remove the top cover from the freezer door hinge and disconnect the plug . This removes power to the door . Use a small screwdriver , and pry the bottom of the dispensor display board outward . Remove the 3 plugs . Remove the 4 screws on the white dispensor housing ( 1 on each corner ) and slide the housing out . In the top right , inside the dispensor area , you will see a solenoid with a plunger . These 2 parts usually rust , and have to be replaced . Pt # WR62X10055 . Only 3 screws hold this piece on , so it can easily be replaced .
Sep 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
My GE model GSS25JFMDWW Ice despenser door does not close properly, allowing warm, moist air to enter the freezer and ice/frost build up. What would be the exact repair procedure for this problem?
First , remove the top freezer door hinge cover , and disconnect the plug there . This removes power to the door . 1 ) Use a small screwdriver on the bottom of the dispensor board , and twist to unsnap the bottom of the board . 2 ) Remove the 3 plugs from the board . 3 ) remove the 4 screws , holding the dispensor cover on , and slide cover out . 4 ) At the top right , you will see a black solenoid with a plunger ( usually rust ) . This is the part that needs replaced . Pt # WR62X10055 . This part comes with the plunger . Do not try to just clean , as this problem will happen again if not replaced . Re-assemble in reverse .
Sep 27, 2009 | GE Refrigerators
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is forming in the door dispenser,damming up in the ice dispenser and blocking ice from being dispensed. Model is ZFSB23D SS. I have taken the parts off of the freezer door several times to remove the...
It sounds like the dispensor flap is not closing . Can you look down the ice shoot , and see daylight ? If so , dispensor and plunger need to be replaced . Pt # WR62x10055 . Or , if crushed ice is used quite often , this too will cause the shoot to jam . Unfortunantly , only cure for this , is to use less crushed ice . Since you've taken parts off the door before , I wont go into , how to get to and replace the solenoid and plunger .
Aug 31, 2009 | GE Refrigerators
GE GSS25JFM Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
