Question about HP Office Equipment & Supplies
My M-2727nf fax says '' Device is Busy try again later''
  • 231 Answers
Go to HP website and download the latest firmware update for this device.
They were released with several 'bugs' in the system.
Posted on Dec 07, 2009
HP 2727nf fax machine Fax not working what is the problem ?
Get an analog phone to test your phone line first. Then, make sure this line is connected to LINE port on your fax machine. Use the same analog phone to connect to the EXT port to test the line again.
Use another line to call this fax number to see whether the analog phone rings. Once you know the line and connection is okay, let's reset your fax machine. See http://www.fixya.com/support/t2503076-hp_laserjet_m2727nf_mfp for the cold reset instruction.
Dec 13, 2016 | HP LaserJet 2727NFS All-In-One Printer
HP LaserJet 400 colorMFP M475dw + Scan to Email + Device is busy, Try again later
If I'm getting this right, your printer says "Device is busy, Try again later" when you try to Scan to Email ? Make sure your Scan to email-configuration is set up correct. Still no luck ? Leave the printer without power for 30 min. You can also try a factory reset. If nothing help, check if your printer is still under warranty HERE. If still warranty call your local HP support and ask for service.
Nov 04, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
HP CM 2320 nf MFP keeps saying...... fax line is busy....
I had this problem as well - try the following:
1) Change your rings-to-answer from the default of "1" to "3". This is found in the basic fax setup on the control panel of the printer itself.
This solved the problem for receiving faxes that I was having when testing fax reception by the HP 2320nf from an dedicated fax. The remote fax would fail after repeated rings with a "BUSY" indication in the fax error report it printed. "BUSY" equals either actually "busy" or also it can mean "no answer".
What I found on the 2320nf end was that it had detected an inbound fax but never answered it. The color LCD on it had "fax received" but the device itself appeared hung.
Hope this helps.
Mar 30, 2011 | HP Laserjet CM2320nf All-In-One Color...
BUSY SIGNAL UNABLE TO RECIEVE FAX
You should unplug your fax machine from the phone wire and call your fax number to see if it is still busy. If it is then you have some other device sharing the line that is holding the line busy or a short in a wire. Remove all other devices (computer modem, credit card machine, cable/satellite box, alarm system etc) and check again. If it is still busy you may have to call your phone company to have them diagnose the problem. If the line is cleared start adding each device back to the line and check between each to see if the line busy's up. If it does it may be the device or the wire (the wire may be damaged and shorting the line).
Jun 15, 2010 | Brother IntelliFax-4100e Fax
Device is busy error
Check on the bottom right of the screen you will see a small printer icon.
Double click on the icon. That will open up the Print Queue.
Look at the print jobs. If one job shows as Spooling, click on the job and then delete it.
Don
Jan 18, 2010 | Lexmark Office Equipment & Supplies
Busy, try later error won't go away
depending what rollers and how you did it, you probably have 'spun' a clutch out of position so it can't find it's 'home" position, and keeps on trying. If it worked before cleaning and now it doesn't you've definitely broken or dislodged something like that.
May 25, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
96 people viewed this question
Seeker5211
Seeker5211
