Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I don,t know how to copy files on a scan disc
What comes next after putting the scandisc into the usb port
  • 71 Answers
Open Windows Explorer, assuming you're running Windows, and the flash drive should show up with a drive letter, e.g. as E:\ (Doesn't matter what letter.) Copy or drag the files or folders you want to move from this drive to your hard drive, assuming that's where you want them.
It's a good idea not to use Cut and Paste when doing this so the original still exists on the flash drive in case of problems.
Once you've copied what you want from your flash drive, you can reformat it if you wish. Click on Safely Remove Hardware before removing your flash drive from the USB port.
Posted on Nov 17, 2009
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
Is there another way to read a scandisc memory stick if i can not find a slot for it? i have a toshiba C655 windows 7? I also have a scan disc ultra that i can not insert in either. Do I need to bring it...
If you are refering to a flash memory card for a camera, one can purchase a memory card to USB2.0 adaptor, which will connect to your computer's USB port.
If your computer does not have a USB port, a black and sliver rectangular port. Then you will need to copy the media to another readable format, either on a friends computer or at Walgreens. Such as a CD or DVD.
Take care!
damnor01
Apr 29, 2012 | Toshiba Computers & Internet
Would you know the answer ?
The packard bell easynote h5315 has 3 USB 2.0 ports. The many product reviews on the internet don't say exactly which ones are high speed. Ultimately it doesn't really matter unless you are thinking of copying large files greater than 1GB then it will take longer on a low speed port.
To test this I suggest you put a file larger than 500MB on a flash drive, then plug the flash drive into the first port and copy the file back to your notebook. Take note of the time it takes. Repeat this step with ports 2 and 3. Review the results together, the port/ports that copied the file the fastest are your high speed ports. The port/ports that took longer to copy the file are low speed. If all the ports take similar times to copy the file then all 3 are low speed ports.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
I have a F2280 that scans but don't know how to do it. can you help?
Hi
Open your control penal and select the scanner and camera the new window is come put the your document in your scanner and select the next first option is file name and second where u want to save select the destination and click next your scanner scan your document wait second of earth and finish
your document is scan
good luck
May 05, 2011 | HP Office Equipment & Supplies
My scandisc was in the usb drive working fine all at once the light on the scandisc went out and now it does nothing i need help to get the data off of it stored for work computer does nothing when I plug...
Have you tried plugging it in another computer? If it worked, then the USB port on your computer (the one the scandisc was plugged into) is burned. If it doesn't work in the other computer, then the USB drive's chipset is burned ... unfortunately, data recovery is very difficult, but there are specialized companies that do this.
Aug 24, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Usb drive use
Most thumb drives are used like floppy or rewritable optical discs (excluding ReadyBoost and the bootable versions). They are most often formatted as FAT drives (under Windows). If the drive is good and the USB port is good, plugging the drive into the computer's port should trigger a "new hardware found" message from Windows.
In Windows, open My Computer or Computer (depending on the OS) and you will see it listed under Drives with Removable Storage. You can use the file explorer to navigate through your regular drive and copy files to the thumb drive or the reverse. (I usually open two different windows and drag the files with a right-click then select Copy.) Synch programs can let you keep the thumb drive and hard disc copy at the same version. Alternatively, you can save a file directly from the program that you are usng to edit the material. (File > Save As and chose the destination). You can also open the file from the thumb drive in a similar mode. To avoid lost data, always select the Safely Remove Hardware from the taskbar (or Eject from the File Explorer) before unplugging the drive from the port.
The biggest problem is that the FAT formatting limits the number of files you can put on the disc unless you keep them in folders. (The same number of folders can be in the home directory as files without using folders.)
Bootable thumb drives (as well as those that can run software directly from the USB drive) come with software that lets them do this. Then they act like any optical disc with Autorun and executable programs. Readyboost is dealt with completely by the OS and keeps the drive (or portion of the drive) separate from the area that will store files.
Sometimes these drives do fail. Getting the data off the flash memory takes a professional most of the time.
I hope this helps.
(You can copy all of the files from the thumb drive and reformat it at intervals. Then copy files back if you are concerned about file fragmentation.)
Jul 24, 2010 | Verbatim VER95327 USB Hard Drive
How can I install a conon pixma ip1200 without a disc
yes copy the driver from a network location or in USB pendrive;extract it if it comes in a zip or rar files.
click start select prineters & faxs;click add new printer click next;select local printer with your prinetr on and make sure you untick "automatically detect and install plug & play devies"
leave the port setting as selected by default;click next then have disk and browse for the driver folder and select .inf file and click next. it will start installing as you want it that way.
i hope it will solve you rproblem
Dec 07, 2009 | Canon PIXMA iP1200 Photo Printer
How do i down load music frm laptop 2 usb help plz in plain english
Put your USB Pen into the USB Port. Go to the folder where you keep the music file on your computer, right click on the file and highlight 'send to'. This should then give you a choice of options, one of which will be 'removable disc' This is your 'usb pen drive'. Select this option and the file will copy over, you should get a box comes up telling you that it is copying.
Feedback is always appreciated
JEnny
Sep 14, 2009 | HP Pavilion dv9000z Notebook
My Canon MX310 will not scan pictures -
it sounds like a file is corrupt,if you have a driver disk,delete everything and redownload it.a file might not have copie right the first time.
Jun 09, 2009 | Canon MX310 Office All-In-One Printer
Micro scandisc 512 MB
I think I know what you want. The smartcard device plugs into the back of the pc. It's a serial port connection. The memory card plugs into the smartcard device. I have a question, does your cell phone have a memory slot for the memory card?
Jun 22, 2007 | SCM Microsystems SCR131 PC Card Reader
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
88 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
