Question about Cuisinart DLC-5 Food Processor
Cord has a **** in it - Cuisinart DLC-5 Food Processor
  • 71 Answers
So replace the cord with one that doesn't have a ****.
Posted on Nov 17, 2009
How do you replace the power cord on a Cuisinart DLC-8M.
put the screws back and leave the cord alone it still works
Jul 13, 2016 | Cuisinart Food Processors
Repair electrical cord inside model
could be there are screws on the bottom of it .
May 21, 2016 | Food Processors
Motor will not start
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
Bought as a gift food processor modelfp2500b never got it to work
follow this steps and fix it. God bless you
If the food processor won't run at all, be sure power is on at the outlet and check the power cord Check the motor +fuse.468af34d-690c-4533-b2aa-a29c6cf267c4.jpg
Oct 29, 2013 | Food Processors
Can you replace a melted cord
I posted the reply pasted below on how to take the Bullet apart - really not difficult once you know where the hidden screws are apart. Once apart it easy to see where the power cable terminates and should be easily possible to connect in a new cable in its place.
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Aug 22, 2012 | As Seen On TV Magic Bullet Food Processor
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
Kenwood FP460 food processor, can it be opened up to replace a damaged power cord? If so how?
Yes. First, unscrew all the screws from the bottom, then, gently, pull it out. Please note that you need to have basic electricity knowledge in order to properly disconnect and reconnect the power cord.
Jan 19, 2011 | Kenwood Food Processors
Repaired cord is not working
make sure the plug is wired correctly .. the colors of wires depend on what country it came from .. in the US it would have a black, white and green wire ... the black wire would be connnected to the small flat prong (thats the AC hot wire) .. the white wire would be connected to the wide flat prong (thats AC return) and the green wire would go to the round grouund connection .. if these are not wired correctly then it may not work and could be dangerous .. have it checked by anyone that is familiar with electronics .. make sure the pup didnt chew another spot on the wire ... ..
Jul 02, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
The cord got on fire and it needs to be replaced
www.dealtime.com/xDN-kitchen_electrics_accessories-general_electric_griddle_parts -
Jul 07, 2009 | Cuisinart Food Processors
Cuisinart DLC-5 Food Processor Logo
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
