Question about HP LaserJet 4250n Printer
White streak right side of page - HP LaserJet 4250n Printer
  • 43 Answers
Try shaking toner cartridge and print configuration page, if print ok then replace toner cart.
Posted on Apr 24, 2010
  • 64 Answers
SOURCE: HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Posted on Jul 31, 2009
SOURCE: My drum is at 40%. I have black vertical streaks
I was going crazy! Had a tech come in and look at the machine - needless to say he did NOTHING! A friend came over and was trying different things. It was that the "rack" that the toner cartridges sit in was not fully seated - once he pushed down a little and heard it "click" I had no more black streaks. AMAZING
Posted on Mar 31, 2009
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
  • 990 Answers
SOURCE: streaks on my laserjet 3800
Hello sir; Remove the transfer belt unit, at the end of the unit you sill find cleaning unit, vaccunm it up, if neccesary, replace cleaning blade .
Posted on Oct 21, 2009
sfender713
  • 397 Answers
SOURCE: I get a light gray
Try cleaning the wire grid- sounds like you have some gunk on the corona wire- in the printer under the toner cartridge is a wire grid that charges the paper before toner is applied- if there is gunk on those wires, you will get the smudge you described. You may want to use an antistatic brush and you *WILL* need to remove the power from the printer. Also, if you have one, a vacuum approved for both ESD and capable of vacuuming toner- don't use a standard shopvac, bad things like toner stuck in the motor of the vacuum and causing fire may occur. Fair warning, be prepared for something nasty- last time I had an issue similar to that ended up with me pulling a toner-caked, extra-crispy palmetto bug (Think of your standard cockroach, then triple or quadruple the size.) out of the corona wire.
Posted on Oct 13, 2010
Streaks on my laserjet 3800
Oct 21, 2009 | HP LaserJet 3800 Printer
Jul 30, 2009 | HP LaserJet 2820 Printer
Looking for laser jet printer maintenance
take the toner cartridge out and shake it and redistribute toner.
May 19, 2009 | Office Equipment & Supplies
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Copies have a white streak near right side of copy canonpc920
PULL OUT THE CARTRIDGE AND SHAKE IT, IF THE COPY IMPROVES ITS OUT OF TONERAND NEEDS REPLACED
Apr 07, 2009 | Canon PC-920 Black and White Copier
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
White Streaks down left side of page.
Shake the toner hard and try again. It should work.
Dec 11, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet 4250n Printer Logo
182 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
