Question about Nokia 6300 Cellular Phone
The blue side bars light up and stay on, nothing on the screen. Have tried new battery. Is there a recovery proceedure I can use? some times it on but during using it hanged
Would changing laptop's hard drive help get rid of 'PC needs to be repaired' blue screen?
If you have access to another PC, you can put the drive in there and "format" it. That will wipe everything from it, so you can load from the recovery CDs. Likely no need to buy new drive.
Oct 22, 2015 | Computers & Internet
My sensor bar is on for the wii w/ good batteries an i can c the blue light but no matter how i place the bar or wher i stand i get no redicule on my home screen an ive tried resetting the bar plenty
Do you have a smartphone with a camera? If so, turn the sensor bar on, and point the camera at it (while in the camera app on your phone). You should see two sets of lights coming from the front of the sensor bar on the sides:
http://upload.wikimedia.org/wikipedia/commons/2/20/Nintendo_Wii_Sensor_Bar.jpg
Yours is wireless I assume, so it won't look exactly like this one, but very similar where the ir lights are glowing. If they ARE glowing, try a different controller. If they aren't, replace your wireless sensor bar.
Feb 11, 2015 | Video Game Consoles & Games
"Encryption Unsuccessful" screen on Droid RAZR HD
Have you tried to perform a HARD RESET on your phone?.
to do this you first need to power off your phone.
With your phone POWERED OFF press the VOLUME UP and VOLUME DOWN keys AT THE SAME TIME. Once you have depressed BOTH VOLUME KEYS press and hold the POWER key.
Once you have depressed ALL 3 KEYS ON THE SIDE OF THE PHONE the "BOOT MENU SCREEN" should appear.
When the "BOOT MENU SCREEN" appears, release ALL keys select the "RECOVERY" option, the phone will re-boot and you will see the "Motorola" logo. Eventually the "Motorola" logo will be replaced by the "ANDROID IN DISTRESS SYMBOL" (the "ANDROID" with an exclamation point in front of him). Press ALL 3 keys on the side of the phone once again, tap and release the VOLUME UP key, you should then see a BLUE MENU SCREEN,
oNCE YOU SEE THIS blue menu screen SCROLL DOWN TO THE "wipe data factory reset" OPTION.
oNCE YOU HAVE SUCCESSFULLY COMPLETED THESE STEPS THE hard-reset PROCEEDURE WILL BEGIN. WARNING THE HARD RESET PROCEEDURE WILL ERASE ALL OF THE DATA THAT IS CURRENTLY STORED ON YOUR PHONE SUCH AS PICTURES, MUSIC, YOUR CONTACT LIST and so on. SO YOU SHOULD DO A BACKUP BEFORE YOU START THIS PROCEEDURE. I hope that this information is helpful to you!!!.
Apr 07, 2014 | Motorola Mobility Droid RAZR HD
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
My nokia 6300 will not power up.
You can try updating the firmware using a Windows XP computer, which will also reset the phone to factory defaults (and thus probably fixes your problem).
Download the Nokia Software Updater from: http://europe.nokia.com/A4579163
Connect your phone to the computer using an USB cable, run the program and just follow instructions. Please note that you'll lose anything stored in the phone's memory (but not the SIM contacts !).
Whenever you still have warranty, you could take it to a Nokia Care center and have them update/reset your phone ...
May 06, 2009 | Nokia 6300 Cellular Phone
Hard drive failure
www.drivesavers.com
www.ontrack.com
You can contact this companies regarding data recovery. The "Genius" was wrong about the drive being retuned to Apple, that will only occur if you have a system under warranty, and you would be returning it to Apple to avoid being charged.
As far as replacement hard drive going for $325, that too is pretty steep, see this link:
http://search.ebay.com/search/search.dll?from=R40&_trksid=p3907.m37.l1313&satitle=MacBook+Pro+hard+drive&category0=
Apr 06, 2009 | Apple MacBook Pro PC Notebook
Nokia 6300 Cellular Phone Logo
119 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
