I have no sound on my PC. everything is plugged where it is supposed to be. I can't find the page where you adjust the volume and mute the system. HELP, Someone!
  • 92 Answers
Press start, control panel and the sound. Try uninstalling the drivers for the sound and reinstall them....Hope this helps....
Posted on Nov 17, 2009
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Classic View
Click Sounds and Audio Devices
Click to place the Volume Control on your screen.
Dell latitude D610 will not unmute
    • 1 Click on the speaker icon in the system tray of your windows 7 screen, located in the task tray by the system clock. This will cause a volume adjustment screen to pop up. Drag the volume slider to adjust the volume higher or lower.
    • 2
      Right-click on the speaker icon and select "Open Volume Mixer" to manually adjust the volume of each device separately, using the same method as in step 1.
    • 3
      Right-click the speaker icon and select "Sounds" to change which sounds play for specific events, such as Windows Startup, Windows Logon and System Notification. This should bring you directly to the "Sounds" tab of the sound menu, where you can click the program event from the list and change the sound using the drop-down menu at the bottom. You can choose "(None)" to disable the sound.
      car headlights.
Jun 01, 2012 | Dell Latitude D610 Notebook
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
Step three says connect to computer. I plug the green speaker prong into the green port on my sound card. I get windows sounds, but no sounds from CD or videos online. Any ideas?
Many applications (like web page videos, media players) have their own volume controls, separate from the main windows control. Since you can hear other sounds, I would guess that the volume is lowered/muted on these applications. To check this, look for a slider bar or speaker icon on the web page, or the media player. Adjust slider up, and also check for a a mute button (often a red circle over the volume control). Adjust and re-test, and you should be good to go.
Sep 12, 2011 | Dell OPEN BOX AX510PA Multimedia Speakers
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Volume
re install the driver for your audio device.compaq will have the download you need
Dec 30, 2008 | Compaq Presario Notebook
Hp zv5346us audio problem
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Oct 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Lenovo laptop with terrible beep-sound when power-supply are plugged in- and out
If you're using to Lenovo Ideapad U330 click on the volume setting and go to options: properties.
Select PC Beep and then adjust the volume to your desired level or mute completely
May 14, 2008 | Lenovo 3000 V100 Notebook
No audio sound and decreased hard drive storage
First check that your sound isn't muted or turned down way low in windows. Do this by clicking on the start button, then clicking RUN and typing 'mmsys.cpl' without the quotes to bring up your sound & audio properties. If there is a check next to mute click the check to remove it. Next click on the Audio tab along the top. Now under sound playback click the volume button to bring up the Volume control. Again make sure nothing is muted. Now the left slider is your main volume control so if thats really low pull the slider up a bit. I would put everything up on high and adjust down from there.
If theres still no sound then the next step would be to reinstall the sound drivers. You didn't post your exact model but you can find the drivers yourself on here http://www.everex.com/support/support.htm If you have any more questions just post and i'll get back to you.
Jason @ JRDTech.net
May 14, 2008 | Everex StepNote NC1500 Notebook
Sound
Check headphones or speakers are not plugged into the output plug for the sound card and if they are they are powered on.
Go to Start>Control Panel> Sounds and Audio Devices>Adjust the system volume and make sure the volume is up and Mute is unchecked.
If you are using a laptop, or a computer with a keyboard with volume controls, make sure these are not muted or down low. Check your user manual for exactly how to use this if you are unsure.
Nov 14, 2007 | Edirol UA-4FX External Sound System
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
