Question about Frigidaire Refrigerators
Water coming out from under front of refg - Frigidaire Refrigerators
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Nov 17, 2009
Refg light will not stay on. Unplug refg then plug back in light comes on for a few seconds. Then goes off.
If the lights are leds, then the led driver module is going bad. If the light is a regular light bulb, try tightening the bulb in the socket.
Nov 13, 2016 | Refrigerators
No water in tray no ice being made. Water
water inlet valve in basement under refg. or behind it .
Nov 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Refg Model FRS24ZRH that leaks from the doors. cannot find where it is coming from.
Sep 05, 2009 | Refrigerators
Tring to hook up waterlines to dual valve
Probably to the filter is where the other one goes if you have a filter.
Jun 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Water button not work
You can check the site again on how I fixed the same problem. GE also has a recall on many refg. with this same problem. Probly a frozen line inside dr.Quickest way to isolate is to disconnect line at were it enters bottom of dr. and press dispenser tab. If you have water to this point it is about 99% sure a freeze in dr. No water means probly selenoid or the switch or something else. Ice and water line do not feed off same line , ice will dispense even if water does not.
Dec 24, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
