Question about Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp LC-52SE94U shuts down and restarts automatically
Have Sharp LC-52SE94U and regularly, but randomly, I will be watching local channel HD broadcast (antenna) and will hear click. Screen will go black and sound will die, but blue power light remains lit and steady. After about 10 seconds, picture and sound returns. Luckily, all the times this has happened we haven't been holding onto the remote -- so we didn't accidentally do anything to make the set think we wanted to turn it off or something.
Almost acts like the set thinks it had been physically turned off and then on again. I say that, because when I first turn on the set, startup process acts exactly the same as when it starts up after problem causes it to automatically shut down and restart. Any suggestions?
Chuck Parker
  • chazp Nov 19, 2009
    tvtek, thanks for suggestion, however I am nearly certain that 080931 firmware update was applied since Sharp mailed me a usb stick with instructions to update firmware a while back. Is there any way to actually tell what version of firmware is installed in the TV? Chuck
  • Mark Hudson Feb 19, 2014
    It's the board inside where main controlls are. It is touching the inside frame causing the tv to short.
    President:
  • 1,284 Answers
There is a software update for this model via the Sharp website. Included is a link to the compressed folder. Once you uncompressed the folder there are instructions in the folder on how to install the update. It doesn't specifically say this is a fix but as a TV technician personally its the fist thing I would try.
Link to Sharp software update
Posted on Nov 17, 2009
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Does the sharp Aquos LC-52 support HDCP? I have Dish Network and for some reason can't watch any HD PPV channels, Dish Network says it's a TV issue. Can you help?
DISH Network blocks multiple video outputs on all PPV and most premium content to prevent recording, and they will tell you it is a TV issue. Ensure that your receiver only has one video cable coming out, to only one device (ie HDMI to the TV) and try again.
Oct 03, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-52SE94U 52 in. LCD HDTV Logo
1,136 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
