Refrigerators Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take the wheel studs of a 1990 dodge w250?
  • Anonymous May 11, 2010
    Generally with a hammer - studs are pressed in; they don't screw in. You can use the hammer to put the new one in too. Ask wherever you're buying the studs. My experience is with a Ford. The studs were several times more expensive from a Ford dealer than from an auto parts store. And you should probably know what length you want.
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Nov 17, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
Helped
27176
Points
245
Vacuum Diagram for 1991 W250 with 360 engine
Get a Hanes Manual from PepBoys. Everything for your vehicle is there.
1helpful
Needed: dodge w250 diesel 1990 frame dimensions, side view
genuine workshop manuals have a frame measurement section for the straightening process of the chassis. You may get the information from a small truck body repair shop
2helpful
How to change vacuum pump on 1990 dodge 250 diesel
The vacuum pump in the Dodge W150-350 Cummins Diesel is integral with the power steering pump on the driver's side of the engine. remove it as one unit from the accessory drive unit. Then you have to press the gear off the shaft to separate the power steering pump from the vacuum pump
1helpful
Four wheel drive will not engage
check the vaccum hoses, mine would not engage on my truck i have a ford. if there is even these slightest whole in the vaccum line it will not let the 4wd engage. if that doesn't solve the problem check the 4wd actuator. i replaced the hose on mine and fixed it right away..
2helpful
I have a 1993 Dodge W250 cumming 4x4, to anyone who knows transmissions, i've had mine apart and together twice now and still can't get reverse to work, the sprag is fine the reverse drum only rotates one...
Have you checked the line presure? I had one of these that had an internal leak in the vavle body. My tranny buolder pulled his hair out every time i gave it back to him. Good luck
Is an upper ball joint threaded?
Yes it is threaded and requires a special socket for removal.Channelocks can be used in a pinch but is quite tedious.Many times I have also had the heat the control arm up to get these to unthread.
1helpful
Want to know the weight of my 1990 w250 diesel?
That unit is 4900 pounds. Impressive- now you have a towning compacity of 7000 pounds- I would recamend checking your rear diff for leaks and how old your struts are and if your leaf springs are tired, and check your brakes!! I know with the manual you have more towing compacity but I don't know the total, your post is old- and you probably know by now. Good luck.
1990 Mazda MPV Slippig Transmission
Try changing the transmisson fluid and filter and put in a additive for the oil.
1990 dodge ram w250 swap to crossflow radiator and intercooler
I would consider buying your core support from you. 352-552-1159
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
