I have tiny n19 wireless has stopped working says turn on switch i cannot find it any ideas
  • 561 Answers
Ensure your button lock is not set to on. usually to switch on you have to hold one if the buttons in for a few seconds and then it should start try each button in turn.
to switch off it is the same just hold the button until it goes off.
Posted on Nov 17, 2009
Asus Wireless Stopped Working
I answered this question before however the switch may also be faulty that is possible or the keyboard may be faulty as well. I would have it checked out by a pro to see what the real problem is. Or if you want to bypass all that then just go and get a wireless USB stick and go that route as well. That is another option if you do not want to pay to have it fixed. You can get them cheap at amazon.com for around $15.00 or less. John
Apr 19, 2012 | ASUS U Computers & Internet
My hp wireless mouse has stopped working
turn the mouse over, press and hold the tiny button on the bottom. At the same time - find the transmitter connected to your pc and press and hold the tiny button on it too and hold both buttons down for a few seconds. This will calibrate your mouse and return it to working order.
Oct 09, 2011 | HP Wireless Optical Mouse
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
My HP wireless mouse all of a sudden stopped working (usb connection to my laptop.) I did change the batterie. Do you have any idea what is going on?
Try to completely shutdown your computer when you connect it and turn your laptop back on once the pc is already booted back up switch on the mouse...
Mar 19, 2010 | HP Wireless Optical Mouse
Wireless switch not working on ASUS F3T series
Hi
Please install ATK driver properly & wireless console also your problem ll be solve any more query then ask me
Harry
May 15, 2009 | Computers & Internet
2003 Jeep Liberty Electric Mirrors only move a tiny bit then stop
it sounds like the switch is going bad in the mirrro switch on the driver door should be able to get on at any dealer it should be any fix
Jan 25, 2009 | 1999 Jeep Grand Cherokee
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
The screen of my laptop comes up with squares and small circles on reboot
Normally I would say this was a driver issue, however ,since you reformatted and reloaded your op system and it still does the same, I'm going to say it's either the inverter or the screen. Check the connections to make sure they haven't worked loose.
Jun 21, 2008 | Packard Bell (181379) Motherboard
Computers & Internet Logo
David Payne
David Payne
