FixYa.com
Tags:
Nikon TC-17E II for AF-S, AF-I 1.7x Lens Converter
Nikon TC-17E II with Nikon 70-200mm f/2.8 (by 2 users)
posted by MattHH on Jan 10, 2008
I bought a Nikon 70-200mm f/2.8 lens and Nikon TC-17E II (both new) this week for use with my Nikon D300.
Put the Nikon 70-200mm on my D300, it works beautifully. Couple the TC-17E II with my Nikon 105mm, again a beautiful combination with lovely sharp macro photos (but manual focus as autofocus does not work with the 105mm).
But put the TC-17E II and 70-200mm and autofocus only sporadically works. Most of the time I get chattering over close focal lengths...sometimes it will focus, but not up to my expectation given I have heard the TC-17E II was designed espcially for the lens. I am not convinced it is lack of light or contrast causing this problem.
Any suggestions about what I can try to remedy this problem. I am currently using the teleconverter with manual focus.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Blax_R, posted on Feb 25, 2008
I also have the Nikon 70-200 & TC-17E combo and am not impressed. I can get sharper shots by removing the TC-17E and cropping the photo. Now, I am trying to decide whether to return the teleconverter or keep it to use with a macro lens. The 70-200, incidently, is the best lens that I have ever used. I just wish that I could get the longer reach for birds and nature shots. I'm considering the 80-400 (the 200-400 would be my choice if was more affordable)
Best Solution
posted on Jan 25, 2008
FixYa! (100)
JoelB
Rank:Wiz Wiz
Rating: 88%, 37 votes
You may have a dirty contact on the tc cpu pins. Try cleaning the pins with a clean pencil eraser or some methanol. You could also have a loose connection between the tc and the lens or body. Try applying a rotational force in both directions...see if you notice any change in behavior. If you have a local shop, see if you can try another copy on your lens.
The 17e may have slow-ish performance in low light, but it should still be usable. If neither of these issues is apparent then it may need to be exchanged or serviced.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Camera Lenses problems?
Camera Lenses
camera not displaying
Hi, my ICAM Robo-351 is being... Answer This...
Camera Lenses
Digital Camera S760 Sumsung....
I have a digital camera. Its a... Answer This...
Camera Lenses
HELP ME TO INSTALL
please help me install my A4... Answer This...
Camera Lenses
af motor required for a canon...
HI, My name is Nick, I'm trying... Answer This...
Camera Lenses
test dont answer
test dont answer Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
