Question about Kenmore Ovens
I have an Inglis gas oven which stopped working. The oven lights only some of the time and seems to get progressively worse. This has happened once before and turned out to be something very simple requiring adjustmentand cleaning of something in the broiler drawer. I'm trying to avoid calling for pricey maintainence.
  • 10,515 Answers
It doesn't work at all
No power
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Top burner doesn't work
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
It doesn't bake
Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
It doesn't broil
Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
If you are certain the igniter is OK, it might be a good idea to call a professional appliance technician.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 17, 2009
  • 3,741 Answers
Oven lights get progressively worse due to some reasons.to solve the issue there is a procedure click this link directly to get the exact detailed procedure step by step http://www.premierrange.com/faq-lightingrangepilots.htm follow the mentioned procedure and then check out the light in oven it will work properly. -------- if still the same problem there must be problem in the igniter coil .to check and repair/replace the igniter coil click this link directly http://www.applianceaid.com/gas_ignitor.html ------- gas range flames die when I turn on more than one thing at a time: This is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristicsshould look like. ---- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
My 900GRa Rotostar Gas Double Oven & Grill . When i switch on the Grill it continues to spark but the gas seems to cut off after few moments then the green light flashes on the turn on switch ? Please...
I had a problem with my gas double oven not lighting some time back !
The problem was solved when i took the oven out and cleaned out the Air Fan duct which was clogged up with fiber & Dust stopping the intake of Air !
Dec 22, 2010 | Ovens
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Oven fills with gas Maytag Appliance MGR5780BDQ
Your ignitor is becoming defective. Even though it is glowing, it is not creating the proper resistance to "pop" the gas valve open. Instead, gas slowly seeps into the oven cavity until it finally ignites and causes a potentially dangerous situation. Call an experienced technician and have it checked.
Oct 01, 2007 | Ovens
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
