Question about Coleman Cable Power Inverter PMP1200
I attach my inverter with custom battery cables and it powers up. As soon as I plug in an extension cord (any cord)it starts beeping. I don't even have anything plugged into the other end.
  • Anonymous Mar 19, 2014
    is my inverter useless now. after plugging a device into it, it starts beeping whether inverter is on or off. what is the problem. pls advise
    Problem Solver:
  • 12 Answers
Please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Posted on Nov 17, 2009
2004 Chrysler Pacifica makes clicking noise without key in ignition
im having the same problem with my 300m they say its cuz the alarm was triggered at some point and it needs reset
Jan 20, 2013 | 2004 Chrysler Pacifica
I can't find a cable to charge the pkc0aq Peak Amp power station plus
You open the door that covers the plug on the lower side and find a extension cord and plug it in and then in to a wall outlet for about 24 hrs
Nov 23, 2012 | PEAK 700 Amp Jump Starter with...
My screen is black
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.If it seems like the laptop is up and running but the screen is not displaying anything then the issue is with the screen. Take a flashlight and shine it on the screen and look very hard and you might see the icons or something very faintly on the screen. If so, your LCD Inverter needs to be replaced. It is located at the bottom of the screen and covered by the strip that goes around the screen. IIf you don't see anything on the screen then try plugging an external monitor to the laptop. I can be any kind of monitor, even the old big fat crt's as long as it has a vga cable that can go into your laptop's vga port. If you see the image on the external monitor, that means your video card is good and the screen needs to be replaced. Sometimes you might have to hit the FN key plus one of the F1 thru F12 keys to get the image to display. The correct F1 thru F12 key will either say CRT/LCD or it will have the icon of a display on it. Press and Hold the FN key then hit the correct F1 thru F12 key. This will toggle the the image to display either on the computer's screen, the external monitor screen, or on both screens.
Mar 25, 2012 | Computers & Internet
Computer does not power up.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Antec SL350 (smartpower sl350) 350-Watt...
Trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
May 26, 2010 | Black & Decker Black Decker 400 Watt...
Inverter beeps when I plug in extension cord. Nothing else
it is possible the alternator's power is higher than that of the inverter ,that is overload
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
Hi, i've got a skytronic 300w soft start inverter making loud beep and then cutting out. I know its one of the safety cut outs but not which one. can it be repaired ? thanks
If your appliance draws over 300W or if your 12 v battery charge is low you will get a loud beep warning. Do you get the same beep with a low current appliance like a lamp? Make sure your battery has a good charge.
Some appliances have huge draw at start up even though they are rated under 300w your inverter may not be able to start.
Also some electric motors don't like modified sign wave inverters.
What are you trying to run and what is its rated watts?
I had my inverter beep when I had it connected via a cigarette lighter plug but when I used a connection straight to the battery it worked fine.
I was running a 500w grinder on a 1000w el cheepo inverter.
Aug 17, 2009 | Electronics - Others
Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Aug 27, 2008 | Xantrex Technology Ags Harness Cable...
Canon Pixma830 all-in-one beeps when I connect it to my phone line
When you attach the phone lines, the line coming from the wall must be put in the "L" (line) jack on the machine. The extension phone can be plugged into the other jack. If you have the line coming from the wall to your phone first, and then the extension line coming to the machine, you will get the beeping. You must have two lines plugged into the machine.
Jan 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Coleman Cable Power Inverter PMP1200 Logo
509 people viewed this question
Top Coleman Cable Electronics - Others Experts
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
