Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Digital channels low power
On my toshiba televisioon (bought Jan 09) the picture keeps breaking up and the words ''digital channel power low'' appear on the screen. What can I do?
    President:
  • 1,284 Answers
The only thing you can do is possibly purchase a better antenna or relocate the current one you have. Go to http://www.antennaweb.org and it will tell you after placing in your address, zip code and surrounding building types what size of antenna you need as well as where to aim it. Pleas take a few moments to rate my respose. : )
Posted on Nov 17, 2009
No picture model Toshiba TV model #32c100u2 get
Does it have a DVD player Combo unit ???
Aug 16, 2013 | Toshiba Televison & Video
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
The TV shut off by itself. Just before it went off, it said "timer off 0:00 press 09". Now when I push the power button the power light blinks and there is no picture.
sounds like somebody set the timer. normally this only makes the set enter standby mode and pressing the power button or a channel button usually wakes the set normally.
Just a longshot but have you tried pressing 09 while the light is blinking?
Mar 21, 2010 | Toshiba CZ32V51 32" TV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Why do the stations keep blinking in and out all day and all night? is this how it's going to be even after 6-12-09? it really gets on my nerves when i'm watching tv and miss over half of whats going on or...
The channels are going off because the signal is not stavying strong enough to keep a regular picture. If you are having this with several channels, there are several things you can check. First, make sure all the antenna wires are not loose. Then find the signal strength option in your converter box (each is different thus you need to check the manual on how to use) to see how strong your signal is. If all channels are low, you most likely need a outdoor antenna. These can be bought at any home improvement store. There is no such thing as a digital antenna. The signal for the channels are still being sent over the same tv spectrum (most will be over UHF) thus walk away from any electronic store that is selling a special digital antenna, there is no such thing. I am using a outdoor antenna, and the picture I receive is just as good as cable. It is some effort to hook it up correctly but the improved picture is well worth the effort. Very heavy rain, wind and clouds at your home and near were the tv broadcast antenna is will also effect your picture. These problems go away as the weather gets better. Directv also has the same problems with weather.
Jun 05, 2009 | Insignia Digital-to-Analog Converter for...
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Toshiba televsion is saying digital channel signal strenth is low
if you're using antenna, (most likely)you need to adjust your antenna to where it picks up the best signal. The picture comes in clear with good audio and doesn't pixelate often.
Feb 06, 2009 | Toshiba MD14FP1 14 in. TV/DVD Combo
Is the Weather Channel TV/Lantern/VEC130B digital?
I have the same TV as in the picture and it is analog(didn't check model #). I know of no way to use a converter box on it short of hacking it apart. Although it can still pick up any low power analog channels that maybe in your area. I just bought a nice hand cranked paperweight just a few years ago. lol
Nov 11, 2008 | Weather Channel COMPACT TV/LANTERN/ EA...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
