Question about Craftsman Garden
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Posted on Mar 28, 2010
I too have the same problem, interestingly, when I removed the air filter my engine ran fine, as soon as I put the filter back in it started sputtering and quit. Still have not resolved.
Posted on Aug 06, 2010
  • austin campbell Jul 08, 2013
    i have the same problem
    Problem Solver:
  • 11 Answers
I have a similar problem. I replaced the carb and drained the oil out, and replaced with new oil. I have cleaned the piston head and cylinder and have tried to adjust the valves. When I pull the cord all I get is a single sputter, and a bit of smoke. I've put wd-40 in the spark plug hole along with replacing the spark plugs. Any ideas? I have the briggs and stratton 7.0 hp engine.
Posted on Aug 02, 2010
If its smokeing in black you might need to replace your rings on the head
Posted on Jul 08, 2013
    if its smokeing in black you might need to replace your rings on the head
Craftsman lawn tractor
you may have a safety switch that has went bad or came unhooked. unplug and test for continuity. also under the hood you will see a fuse, check to see if that has blown. if all that is good you may want to unhook the coil try to start it and see if it has fire. it is possible the coil has went bad. hope this gives you an idea where to start
Aug 16, 2013 | Garden
Craftsman 650 series manual
sounds like a carburetor needs cleaning could be as simple as a fuel line needing to be replaced they do start to break down inside and cause problems
Jun 03, 2013 | Garden
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Briggs Stratton 625 series 190cc lawn mower: this has been tipped right over and now there seems to be oil in everything and it won't go, what can we do?
If the engine has been tipped oil will come through the engine breather and soak the paper filter, remove the filter, remove the spark plug and clean/replace, with the plug out crank the engine a few times to to evacuate any oil in the cylinder, replace the plug and try again ( with the filter still removed ) when it finally starts it will smoke quite heavily so do this out side and on a non grass surface ( oil sprayed from the muffler will kill the grass) it will smoke for some time until all the excess oil has gone, check the oil level in the engine and top up if required.
Feb 18, 2012 | Craftsman Garden
My daughter added oil then proceeded to mow the lawn. mower started smoking then quit. When I got home from work I was able to start the engine one time and it smoked a lot. I turned it off and have not...
With the engine cold, check the oil level. Oil level is quite important especially in a smaller engine. Try to clean all excess oil off engine and body. Then, if you can get it running....check for any leaks. If it is still smoking, it has other issues besides being too full of oil. The oil breather will be full of oil. The oil filter may be saturated with oil. Check those 2 things especially as they allow motor oil to be drawn into the carburetor and cause excessive smoking. Pull out and clean the spark plug. Post back if needed.
Aug 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
After trying to run a water hose through it to clean my Toro 650 190 CC lawn mower has refused to start for me, let me add before the hose I turned it upside down to get out excess grass, Now I've...
Only tilt a lawnmower backwards toward the handle end (spark plug end raises) Other ways move the oil around to places it doesn't need to go. Now you probably have gas in the oil....check it or change it (milky looking or smells like gas..contaminated...might need changing anyway...You probably will have oil in the carb and it will blow smoke...You probably filled the oil breather with oil and it will drain down...causing smoke also. This was the wrong thing to do A 2 year old unit should be mechanically sound..Check the air filter, spark plug and carburetor for oil fouling. Remove the bowl on the carb to help get some of the oil out...it will leak gas when you do.
Jun 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
2,906 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
