Question about Panasonic DMC-TZ5 Digital Camera
I receive an error "Turn camera off the on" At first it was just while in IA mode with auto flash on. Now the error is on when it other settings.
  • 477 Answers
This is a lens error and the lens might need to be replaced if the ring on the camera is bent which happens a lot it might be obstructing the lens. lens repair can cost you around 175.00 for the tz5 lens
Posted on Nov 17, 2009
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
My camera doesnt' work indoors. i try to take a picture and it doesnt' take when I'm in AUTO mode. However, when I'm in LANDSCAPE mode the pic will take. it seems like the flash isn't active in AUTO...
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
Dec 19, 2010 | Canon PowerShot A720 IS Digital Camera
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Bluish colour with Lumix TZ3
I found 2 different Lumix TZ3 cameras.
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097+250033510&Ne=&Ns=&Nr=12001&No=0&Ntt=tz3&Ntk=SupportSearch&URL=vSupportSearch&cmTag=false&cm_sp=&cn=&catalogId=13401&storeId=15001
In the manual, I couldn't find a reference to a bluish color.
In FAQ's, I found the following:
What is “Intelligent Auto Mode” (or IA Mode)?
“IA mode” automatically activates MEGA O.I.S., Intelligent ISO Control, Face Detection, Intelligent Scene Selector, Intelligent Exposure, and Quick Auto Focus to match your subject and shooting situation. IA Mode is a great mode for beginning photographers
http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_032308&catname=Lumix+Digital+Cameras&title=How to Take Better Photos
Jul 23, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
How to set picture resolution.
Turn the camera on and set the slide on the right hand side to the red camera icon, as if you are taking photos. Turn the dial on top of the camera to the red camera icon. Press the middle circle button (menu/set), you will see that the 'picture size' menu is highlighted. Press the right arrow key to view the different resolutions available, select with the up, down and menu/set button. Press the menu/set button again to leave menu. To change resolution in intelligent auto mode, do the same thing but turn the dial to the red camera with the 'iA' in it.
Sep 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Canon IXUS 80IS - I can't turn the flash on
When this camera is in "Auto" mode the only flash functions available are Auto or Flash Off - in order to get the option of "Flash On" for all pictures you have to put the camera in "Manual" mode - to do this:
-Set the mode switch to the camera icon
-Press the "Func./Set" button
-Use the left or right arrow keys to set it to Manual mode (its icon looks like half a camera with the letter M beside it)
-Press the "Func./Set" button again to save your mode change.
Now when you press the flash button and cycle through the choices there will also be a "Flash On" option.
Jul 26, 2009 | Canon IXUS 80 IS Digital Camera
What button do you use to turn off the flash on the olympis 710 digital camera?
Change your shooting mode to available light.
Your camera sets flash to auto when you set to auto mode. There are other modes where you can control the flash manually.
Mar 07, 2009 | Olympus Stylus 710 Digital Camera
Panasonic DMC-TZ5 Digital Camera Logo
231 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
