Question about Kenwood Car Audio & Video
I have a kenwood 600 watt kac-7285 hooked up 2 my highs
Bass comes out my highs
    President:
  • 676 Answers
Use bass blockers or use a crossover.
Posted on Nov 17, 2009
How many watts in a Kenwood kac-9104D
Kenwood KAC-9104D
Product Features
  • Mono subwoofer amplifier
  • 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
  • Variable low-pass filter (50-200 Hz at 24 dB per octave)
  • Bass boost (0-18 dB at 40 Hz )
  • Subsonic filter (15/25 Hz, 18 dB/octave )
Jun 29, 2011 | Kenwood Car Audio & Video
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Keep popping fuse
you got short in the curcuit
Apr 03, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Car Audio & Video Logo
315 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
