Question about Microsoft Windows XP Professional for PC
How to cancel a print job that has multiple copies selected for the print job
    Sergeant:
  • 152 Answers
To cancel a print job and remove it from the spool queue, use lprm, the "line printer remove" tool. Give as an argument the number of the print job to remove.
  • To cancel print job 83, type: $ lprm 83 [RET]
To cancel all of your print jobs in the spool queue, use a hyphen instead of the number of a print job.
  • To cancel all of your print jobs, type: $ lprm - [RET]
NOTE: If you try to cancel an active job -- one that has already been spooled to the printer -- don't be alarmed if some pages still print; the printer probably has some of the job in its internal print buffer. To stop the printing in a case like this, take the printer offline, reset it, and then put it back online again (usually, the printer will have buttons for these commands on its front control panel).
Posted on Nov 17, 2009
  • 92 Answers
On the printer icon right clic and selct cancel printing...Hope this helps...
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
I have a HP 4385 --how do you cancel a print job---it was sent a print job multiple times (over 10) from a Mac and i do not know how to cancel these jobs as they were sent in error and are huge ink...
The printer should have a stop/cancel buttom on the panel, just press that and it sould cancel the print job.
Also, you can delete the job queue from the computer. You should have a printer in the Dock, click on that and select jobs and click on the delete button. If you don't have the printer on the Dock, click on Apple, System Preferences and select Printers. Select your printer and click on Open Queue and delete the jobs from there.
Dec 02, 2010 | Office Equipment & Supplies
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
My HP printer is printing multiple copies of the same document every time I print. The only way to stop it is to cancel the printing job.
it sounds like in your printer driver, the number of copies is set to more than 1 page.
go to printer drivers, and look under printing preferences, and look for what themultiple copies are set to.
Aug 30, 2010 | HP Office Equipment & Supplies
Printer is ''stuck'' on a bad job
Go to computer, control panel, printers, Under you Image runner right click and cancel all print jobs.
Nov 14, 2009 | Canon imageRUNNER 5000 Copier
How do I cancel a print run of 50 copies?
check any cancel botton is there on the printer press the botton to cancel the print other wise switch of the printer.............
Oct 07, 2009 | Samsung ML 2010 Laser Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
Microsoft Windows XP Professional for PC Logo
732 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
