Question about Jazz DV-179 Digital Camera
My camera will not turn back on nor will it charge, when i put it on the charger the light will come on red for about 2 minutes then it goes away
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
My camera wont charge correctly
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 29, 2009 | Casio Exilim EX-S880 Digital Camera
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
When I put my battery in the charger is flashes red.
Hi Olivia. Thanks for your reply.
When the charger flashes red, it means that either:
A) you battery terminals are dirty, or, it's not put in the charger properly.
B) You have a bad battery.
I'm going to assume that you're putting it in the charger correctly because you have had it a long time and know how to properly insert it. The battery terminals being dirty are highly unlikely.
So this is my opinion:
The fact that your battery is a year and half old tells me right away that your battery is a gonner. Your charger flashing red tells me that it can no longer flow current to the battery. I'm sorry, but you need to purchase a new battery. Good news is that they aren't too expensive, approximately $20 usd, and you can find one on the web very easily.
Make sure you get the right battery. Whichever one you buy, make sure it fits your camera. I do know that it's a 3.7 volt np-20 battery. You want to purchase one with a high mAh number. The mAh number relates to how long it will run your camera between chargings. The higher the number, the longer it should run your camera.
Also, note, in the future, don't charge your battery for longer than 2 hours at a time. It should only take 90 minutes to fully charge it. If you charge it longer than that, it will get too hot and dramatically shorten the life of your battery!
Sorry I didn't have good news, but I wanted to make sure you were properly armed with knowledge.
Thanks for coming to FixYa. Come back if you have any other questions, and remember to rate my solution a fixya.
Rob
Mar 13, 2009 | Casio Exilim EX-Z120 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Camera Will NOt Charge
go for the new charger. Keep the battery, always good to have a couple of batteries[I have 3 lions and when I was using AA's I had 6 sets of 4.
Aug 19, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Battery not charging
You need a new battery. That battery goes dead maybe its a factory defect its very rare this to happen but try to contact the Company to ask if you have a warranty for this unit. One more thing make sure that your charger is functioning.
Aug 04, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Jazz DV-179 Digital Camera Logo
14 people viewed this question
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Are you a Jazz Camera Expert? Answer questions, earn points and help others
