Question about Cell Phones
Hi, i cant connect my USB to my tocco lite mobile as it says no driver software was found for this device. How do i sort this please? Amiee
Unlock code for samsung tocco
hi , if it helps a company called" fonefunshop " will have the answer
Aug 13, 2012 | Samsung S5230 Tocco Lite Pink Mobile Phone...
I need usb driver in linux for my mobile samsung sgh x820
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
    usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Dec 12, 2010 | Samsung SGH-X820 Phone
Problems getting phone connected to pc
Tech support at samsung.com make sure you know your model number tocco is not going to work click on mobile, then cell phones then find yours then click download software/drivers
Jun 02, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Hi i would like to unlock my samsung tocco lite can you help to ulock it
There are many methods for unlocking mobile phones, but codes are best one, because it is easy and safe also,
you can get the unlock code for your Samsung model mobile, through this site http://www.theunlockarena.com/samsung-sgh-f480/rs13wp9/
It has the best instructions and easy methods for unlocking mobile phones..........
May 20, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I want to unlock my tocco lite
you can get the unlock code for your Samsung model mobile, through this site http://www.unlocking4u.com/samsung-tocco-lite/rs6wp9/
It has the best instructions and easy methods for unlocking your samsung mobile phones.............
Mar 14, 2010 | Samsung Tocco Ultra Cell Phone
Cant get usb driver for photo download from camera there is no us
hii this is a torrent file and i hope you know how to download it...so try from here all driver are available..
http://www.torrentreactor.net/find/driver-samsung-gts5230
Oct 18, 2009 | Lands Phones
Tocco lite locked, code unknown
if i were you, take it to a computing or mobile phone repair shop.
every phone usually has one code to unlock it, im sure they will sort it out!
xx
Oct 11, 2009 | Samsung SGH-S5230 Cell Phone
Turn answer phone off on Samsung tocco lite mobile
Goto Settings-->Call Settings-->All Calls-->Answering mode.
and check the required options.
Sep 30, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Tocco Lite - Unable to create default folder
Instead of using 'PC studio' option while connecting, use 'media player' option for transferring the files. Check this option. If this does not work, try creating the default directory yourself manually using the phone and then try transferring the files.
Sep 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
