Question about Sharp Video Cameras
My Sharp Camcorder model number VL-H875U will not charge. I have tried a new charger and that will not work either. Any suggestions?
  • mrfeet68 Nov 17, 2009
    I bought a new battery and that didn't solve the problem either. I did check the voltage and didn't get a reading on either battery. How would you suggest checking it. I used a voltage meter set on 10 Volts DC setting.
  • 405 Answers
The battery pack is most likely a problem. Measure voltage across terminals of the battery, if reading is below 1V your battery has to be replaced. Part number of the replacement battery is UBATi0055TAZZ.
Posted on Nov 17, 2009
  • Alex Zoubkov
    Alex Zoubkov Nov 17, 2009
    Any volt meter will do, just check the voltage on your new battery, if reading is low ( around 1VDC). You can try to boost it. Take 9volt battery and connect positive terminal to positive terminal of the camcorder's battery and negative to negative. Hold it connected for one minute. Then try to charge the battery again, if that does not work, camcorder need to be serviced.
Battery will not charge
Dear Lisa
Check may be that battery is faulty ,
or new charge is not compatible with the model
Cheers
Apr 13, 2014 | Sharp Camcorder Battery for VL-E39U
When I plug my charger in too wall for charging, the light for charging doesn't light up nor does it charge my battery.
check that charger is working get it for voltage comming out or just try changing fuse in plug
Aug 02, 2013 | Sharp Viewcam VL-AH151U Camcorder
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Battery or Charger bad?
If you persistently leave the batteries discharged, it is unlikely that they will be able to hold a full charge. You should re-charge your batteries at least once a month, even if unused. Put it on your calendar. BTW 2 years old is hardly 'brand new'.
May 26, 2017 | Sharp VL-E630U Camcorder
I own a sharp VL-A10 viewcam
Negetive external posetive internal.
Dec 03, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp power cord
heres a site were you can get your charger for 24$ - http://www.e-laptop-battery.com/battery-charger/sharp/vl-ah151u.html hope you find it use full
Oct 19, 2008 | Sharp Viewcam VL-AH151U Camcorder
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Video Cameras Logo
62 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
