Question about DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking
Bottom elements on DeLonghi AD699 failed.
Bottom elements on DeLonghi AD699 became distorted. Performance gradually deteriorated and finally they quit working.
Same problem. Bottom elements warped and stopped working. Wish I could replace the elements with another model's because I like this one's functions.
Posted on Sep 02, 2010
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Posted on Nov 19, 2009
Testimonial: "This was helpful to me because I wrote it."
Have delonghi convection oven model A52870B that abruptly quit. symptom of blown fuse. does unit have a fuse?
Hi, if the the toaster already quit, that could be probably the fuse that got busted on your Oven. you can check with any local technician in your area to see on how you can get it changed.
Thank you for using Fixya.
Jul 15, 2011 | DeLonghi Toaster Ovens
Can I replace elements in my Delonghi convection oven?
Don't know about every toaster/convection oven but here is an address that has a list of sites that sell parts. If you can replace then someone would sell the elements.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
ToasterandConvectionOvens.com
Feb 10, 2011 | DeLonghi AD679 1500 Watts Toaster Oven...
Bottom heating element warped then stopped working
can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Sep 28, 2010 | DeLonghi AD699 Airstream Digital 1500...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    BOTTOM ELEMENT DOES NOT WORK
    If the top element is working, then it is either the element, the wiring harness , or the control board.
    Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
    The heating element must be removed and tested using a multimeter.
    The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
    If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
    If the element has continuity, test the wiring harness, then replace wiring harness or control board.
    All the test must be done by a trained repairer, strictly observing all health and safety rules.
    Regards.
    Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
    Delonghi AS690 toaster oven lower element won't turn on.
    Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
    Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
    Heating elements
    The upper element for AS690 is part# 512623
    Thw lower element for AS690 is Part# 512624
    Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
    or
    http://abtecparts.com/delonghi_toaster_oven_elements.htm
    Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
    DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking Logo
    782 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Dave
    Dave
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
