Question about Kenmore Ovens
The oven doesn't heat properly- almost 100 degrees off
  • Kenmore Master
  • 3,463 Answers
From what you are saying, I would say that you have a faulty oven thermostat.
The usual solution, is to replace it with a new one.
Please rate my solution.
Thanks.
Posted on Nov 17, 2009
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
I HAVE A GENERAL ELECTRIC (WALL) OVEN MODEL #JKP13G.. WHEN IO TRY TO PREHEAT THE OVEN TO BAKE SOMETHING IT LIGHTS UP TO ONLY ABOUT 100 DEGREES (BUT DOESN'T GET HOT AT ALL( AND THENIT JUST CUTS OFF. ...
if the clock is cutting out on you it sounds like the computer board or clock assy. same thing is bad but this oven is to old and you can't get the board anymore,it's to old and they don't make parts for it anymore,get a new oven
Nov 08, 2017 | Ovens
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Broiler work but oven wont go passed 100 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 19, 2011 | GE Ovens
Oven wount go above 100 degrees or get hot
heatman101
Jan 11, 2011 | Ovens
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Oven doesn't heat
I'm not sure what properly means.  If the unit is working, you can get a cheap oven thermometer to check the function of the thermostat.  Let the unit come to 350 and check the thermometer.  If it is off by more than about 20 degrees, there is a calibration change method in most oven handbooks.
If the unit is not working at all, this is another issue and needs a different set of diagnostics.
Nov 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
60 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
