Question about InFocus Office Equipment & Supplies
Why won't my infocus projector show full screen videos when it is full screen on my monitor?
Could be a few things,
Is the InFocus Projector Showing part of the video? and when you move your mouse around does it "pan and scan" around the screen? If so, the video, or resolution you are sending on your computer is to high.
If the video window on the projector is just black, but you can see it on your monitor and you can see your desktop on the projector, it is a display setting on your computer. Make the Projector your primary monitor in this case and it will work. Many laptops don't send video to both monitors to conserve resoruces.
Also, make sure you have the aspect ratio set to auto,
More details on the Projector, computer, and video content would help solve it. Its a setting somewhere.
Posted on Nov 18, 2009
  • 2,237 Answers
You have to select it in the menu settings.
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
I have an Acer laptop approx. 2 years old. I am trying to show a folder from My Pictures on a InFocus in 20 series. Projector is up and on computer source. When I start up the computer, the projector...
You need to enable the 2nd video output in the video card settings!
right click on desktop select properties and select the settings tab
Select the monitor 2, click on extend my desktop to this monitor.
Then you can drag windows either out from your main monitor, to up, down, or the sides debends on where you set the 2nd display, you can also change the position of the 2nd screen by draging it around in the middle.
Aug 11, 2008 | InFocus Computers & Internet
Colour dispaly problem in LP 640
are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Mar 29, 2008 | InFocus LP 600 Multimedia Projector
Hey my InFocus LP530 wont detect my pc/laptop, ive changed the auto sorce select to on but still nothing, so i changed it to off and tried all sorces manually but still nothing, Any ideas?
set the pc screen resolution to a low setting.
connect the vga output on the pc to an external monitor and check that the video appears on the external monitor. change the mode of operation on the pc until it does appear.
then disconnect the external monitor at the end of the vga cable, and connect the free cable end to the projector and auto source search for the vga input signal
Apr 20, 2011 | InFocus LP 530 Multimedia Projector
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
The monitor connected to a docking station will not resize after using laptop with an InFocus projector
The inFocus projectors typically force a lower screen resolution - you have to go back and reset the monitor to it's proper resolution. Only takes a few seconds - go onto a blank area of your desktop, right click, select properties, settings, then adjust the resolution. Hope that helps - I've had the same thing happen when using a projector, and have never been able to have the screen automagically "readjust" after using the projector...
May 19, 2009 | Dell 2007FPW UltraSharp 2007FP 20.1-inch...
Cannot see computer displyed on output of infocus screen shot
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Jan 12, 2009 | InFocus LP70+ Multimedia Projector
How to run monitor and projector same time?
You would have to have a dual head video card (two monitor connections) or have two regular video cards, or use a VGA splitter. If you do it through a video card, once you have them installed, go into the settings tab on the display properties and it will show multiple monitors, simply click on the second one and check the box that says "extend my desktop..."
Good Luck!
Dec 05, 2008 | InFocus LightPort (NP-LP98-HT) for PC
Quick Start and User's Guide
My infocus projector will not show a you tube video full screen. It is full screen on my desktop...
Nov 29, 2008 | InFocus LP 600 Multimedia Projector
668 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
