Whats the difference between a a 40 conductor and a 80 conductor on a ide cable
  • 532 Answers
80 conductor IDE wires are designed to reduce interference and other signaling problems associated with higher-speed transfers.
Posted on Nov 17, 2009
Testimonial: "All I got to say is awsome,awsome and more awsome. Thanks"
What are the jumper settings on the drive for the following? Cable select Slave Master
For Slave/Master set up most hard drives have a little diagram on them showing you where to put your jumpers for master and where to put the other one for slave. All hard drives are different. But on your diagram it should say "MA" for master, "SL" for slave and "CS" for cable select.
For Cable select you have to set jumpers to cable selected which should be on the diagram on your hard drive. You will need an 80 conductor IDE/ATA cable. The master conductor is at the end of the cable and the slave conductor is in the middle.
Mar 25, 2011 | Computers & Internet
How to install 80 conductor cable? because when i turn on my computer it displays no 80 conductor cable installed
It means you're still using the 40 conductor cable from the MB IDE to the
hard drive. The 80 Conductor Cables are used to take advantage of the newer
Ultra/ATA-66 and up IDE drives. (They will still work with the 40
conductor cable, but slower.)
Jun 01, 2010 | Microsoft Computers & Internet
How to replace the hard drive in a Twinhead n222s
Find out what kind you have - serial or IDE, get your replacement.
Remove the cover of the computer. Observe static electricity precautions. Find the hard drive. Confirm it is a serial or IDE type drive (IDE has a 40/80 conductor cable about 1 1/2 inches wide - serial cable is about 1/2 inch wide. Dont confuse with the power cable which is a Molex plug.)
Remove 2 or 4 screws if rail mounted. Unlatch if other style. Unplug the cables - check the pin outs - reinstall and get ready for the fun. (you may want to use the old drive - see below. If you are Cable Select (80 conductor wire) the master will be located at the end of the IDE and the slave will be in the middle. If serial, you will have to read the manufacturers direction.)
You willhave to use the manufacturers supplied software to prepare your new drive to receive information. When that is done, you are ready to reload the operating system. You do still have the key right??? No key - don't do this at all. You may be able to use your existing drive as "D" or as a slave (secondary if you prefer) ... to get your old files off or store your new files. All kinds of possibilities are opened to you with a second drive.
Have fun and good luck with your project.
We volunteers are paid with "bragging rights" if this response pleases you please leave positive comments.
thanks
a
Oct 12, 2009 | Computers & Internet
How can i swap the C: drive to the D; Drive and the D; Drive to my C; Drive, in other words make my computer think that my D; drive is my main hard drive?
I can answer you question presuming you have IDE drives ... but ...
where is your operating system? Do you know how to change this from old C to new C?????
An IDE drive can be identified by a wide gray ribbon cable. They come in 40 conductor and 80 conductor versions.
If you have the 80, your computer uses a "cable select" method to choose C and D. Remove both, the one that was D goes on the end of the cable and will become C. The one that was C goes between C and the mother board. On the back of your drives, you should already have shorted "Cable Select"
If you have a 40 conductor cable, you will have to change the shorting pins. Instructions should be on the top of the drive (diagrans to show what pins to short) If you have an extra shorting device when you are done, leave it on a single pin in case you need it later.
I hope this helps you ... and remember, you still need an operating system.
I guess you could (stress COULD) go into the BIOS and make D the the boot device ... but im not real excited about this. There are a hundred things that could mess this up, starting with the default paths that all software come with.
Let me know how you make out ...
a
Oct 01, 2009 | Computers & Internet
More problems lol
Hy Ashley,
First up,
Your channel 1 no 80 conductor cable,
tell me that you have mounted a new HDD to your computer,
If there isn't a 80 wire cable, then the drive that came with the box was not a speedy one.
If you only have a 40 wire cable the drive will be limited to 33MB/s transfer versus 100 or 133MB/s that's possible with the 80 wire cable.
With the 40's, all the wires are signal carriers (potentially). With the 80's, there is a ground wire between each signal wire to prevent bleed over. Bleed over can affect signal integrity, cause errors, and slow down performance.
you can fix that in one of two ways(or maybe both):-):
1. Go into your BIOS, and set it to run the hard drive auto detection to make sure its not holding on to any old hard drive settings.
2. Make sure that all connections are tight. You might want to try a different cable and if you do make sure it is the 80 wire type. The connectors on the 80 wire are colored (black,blue and gray)
The part with it telling you about your CPU is just a part of the testing procedure.
kind regards
/Teis
remember to vote
Dec 12, 2008 | Computers & Internet
Installed a new Optical Drive and require assistance in the wiring
What kind of optical drive? Is this a CD, DVD?, Blue ray,
or an opto-ferro-magnetic floppy?
Generally:
1) External drive:
a) just power it up and connect it to the PC using an USB
or firewire (1394) cable. If it is USB, make sure your PC
is set up for USB-2 which is astronomically faster.
b) The windows operating system should automatically
detect it and install the low level device drivers.
Then you can run the installation driver CD that came
with the drive.
2) Internal drive:
a) Shut down Windows from the START menu,
chose shut down the system, NOT restart.
b) When it finishes shutting down, turn of the
power at the back (!) of the PC and unplug
the power cord.
Now turn the power switch back on for a few
with the cord unplugged, then shut it off again.
This will drain any internal capacitors inside the
power supply to make sure you don't fry anything
while you poke around.
c) Open up the computer case and look to see where
the other hard drives are installed and physically
mount the new optical drive inside the case.
d) Locate a spare power cable coming from the power
supply (Black, Red and Yellow wires) and hook it
into the back of the drive.
It should only fit one way, but there are several
different kinds of connectors, depending on the
drive type, so you may need an adapter cable.
i) Large 4 pin connector = Red, Yellow, Black, Black
ii) Miniature -//- = -//-
iii) SATA power cable = Small black hooked beastie.
Also make sure the power supply can handle
the extra current, this depends on the other stuff
such as drives and video card you already have in
the machine.
If your power supply is less than 600W on a modern
machine, now may be the time to upgrade it.
I have two video cards, 8 hard drives and a DVD,
so I had to upgrade to a 1000W to prevent my
system from randomly crashing during boot up,
when everything spins up for a self-test.
e) Once the power is connected, you need to connect
the data cable, which comes in a least 3 different
types:
IDE or PATA = Parallel ATA ribbon cable
SATA = Serial ATA cable, small flat cable with a red,
blue or orange jacket, and small black
hooked connectors at each end.
Note that these are a different size and
shape from the SATA power cables.
SCSI = pronounce scuzzi, no longer common.
One end of this data cable connects to the back of the
optical drive, the other to the motherboard, but this is
where it gets more complicated, because the mother
boards are fussy about which slot you plug them into.
You need to follow your motherboard manual here (HP) !
For SATA cables, you have to make sure that the motherboard
can handle them, older motherboards cannot, requiring an
adapter card. Also many of the new motherboards offer
multiple drive configurations such as RAID.
RAID = Redundant Array of Independent Drives:
RAID 0 = STRIPE for high speed at the cost of security
RAID 1 = MIRROR for data redundancy at the cost of $ cost
RAID 01 = Stripe of mirrors
RAID 10 = Mirror of stripes
RAID 5 = Stripe with parity compromise
etc...
Anyway, the problem is that on these mother boards some
of the SATA connectors are general purpose (which is what
you need), while others are not (i.e dedicated RAID),
and you may have to change jumpers on the board
or BIOS settings to get it to work right.
Also if the optical drive is to be bootable, then it sould
be connected to SATA1 or SATA2, but that again depends
on the motherboard and the BIOS boot sequence settings.
With the older style IDE or PATA drives, which includes most
optical drives (since SATA is fairly recent), most motherboards
provide two separate IDE ports, each of which can handle a
pair of drives for a total of four.
IDE1, Master = Drive 0
IDE1, Slave = Drive 1
IDE2, Master = Drive 2
IDE2, Master = Drive 3
Each pair of drives shares a single ribbon cable.
Older cables have 40 conductors,
Newer cables have 80 conductors for UDMA.
While the end connectors are the same, only 40 conductors,
the 80 conductor cables have interlaced grounding, which
allows them to transfer data at a higher speed.
Older optical drives used the 40 conductor, newer ones
use the 80 conductor, but there is no harm done using
the 80. If the ribbon cable came with the optical dive,
you can use it if you are plugging it into a separate IDE
port, BUT
Never use a 40 conductor ribbon cable if it is shared between
the optical and the hard drive, because this will slow down
the hard drive to the lower UDMA speed.
Now about the Master Slave thing:
1) Each PATA=IDE port can only handle one master/ slave pair.
2) You must never connect two MASTERS or two SLAVES
to the same cable.
3) The boot hard drive must be a MASTER on IDE1
for most systems, unless the BIOS has a way
remapping them.
4) When a hard drive and an optical drive share the same
IDE port and cable, the hard drive should be the MASTER,
for maximum speed, optical drives are often slower.
5) IDE hard drives and optical drives use a set of
jumpers near the IDE connector to determine if they
act as a MASTER or a SLAVE. This should be set before
you install them, because it is very hard to get at the
jumpers afterwards:
MASTER this forces the drive to act as a MASTER
SLAVE this forces the drive to act as a SLAVE
CABLE SELECT special color coded ribbon cables
(80 conductor) must be used to make this work.
These now come with most new motherboards.
The blue connector at the far end of the cable, away from
the other two goes into the motherboard.
The black connector at the opposite end (near the gray one)
goes into the MASTER drive.
The gray connector in the middle goes to the SLAVE drive.
(both drives should be setup as CABLE SELECT for this to
work)
When connecting the ribbon cable to the IDE drive, make sure
the PIN 1, the marked side of the ribbon goes near the power
connector. On the mother board, the marked of the ribbon
connector goes into PIN 1. The connector should be keyed
to only fit one way, but don't count on it.
Hope this get you started,
Martin
BTW please rate my answers.
Jun 14, 2008 | Computers & Internet
MS 6712 motherboard
check the cables, and if all connection pins are on the drives or on the motherboard. Not all the needed communication routs between the drives and the motherboard are working....
U can also try another IDE slot (if more than 1)
If all checks ok, try a BIOS reset... (but most probably is just the cables ...)
Jan 20, 2008 | Intel Motherboard
MSI P4MAM2-V BIOS
Check your Ide data cable it seems 40 pin conductor cable .
Replace them with 80 pin conductor cable.your problen\m has gone.
Oct 13, 2007 | MSI P4MAM2-V Motherboard
ATA133 refusing to be accepted
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Jan 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
