Question about Electrical Supplies
Dishes not getting clean. Rinsed off dishes have crud on them after its run
  • 1 more comment
  • mhyser Nov 17, 2009
    I can place clean dishes in the dishwasher and run it. They come out with crud on them. It's not food. The unit is a Maytag Series One about 5 years old. I have removed components from the inside of the unit and removed all calcium build up. I can see water below the discharge port. (back right hand side.)I'm wondering if there is crap in the waterpump that gets spread around or if it's coming in when filling. Any chance the drain valve is not closing all the way and letting material back in?
    thanks!
  • dontbother10
    dontbother10 May 11, 2010
    You will probably need to repost to get an answer mhyser. Please include everything discussed here or the answer may be no better. Lou
  • Digglesby
    Digglesby May 11, 2010
    Check the drain inside the dishwasher. Open it & clean it. It may also need a new impeller-small plastic part on mine. This where the crud is supposed to go rather than spread around inside.
  • 71 Answers
Sorry, I don't have experience with that problem & I'm limited to my experience - I'm not an appliance repair person, just fixed what went wrong with mine & yours sounded kind of similar. I'm sure someone else can help you out.
Posted on Nov 17, 2009
Washer doesn't get dishes clean
Try to rinse with vinegar.
Jul 06, 2015 | Viking Dishwashers
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
After washing cycle dishes do have not been rinsed
Not Rincing properly normally referrs to a few things to check. 1)remove both rotors and clean holes properly. Once dishes have been stacked make sure the rotors can turn freely. Try now. Suggest you clean the sieve on the incomming water pipe.(at the valve.)
Sep 21, 2009 | Whirlpool Dishwashers
Salty white dishes
Pour white vinegar into the rinse cycle, this should help.
Apr 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Greasy Film on dishes
You need to use something with citric acid in it like a can of frozen OJ or tang, the citric acid helps break up deposits. (run without any dishes in it) Hope it helps.
Mar 18, 2009 | Frigidaire Dishwashers
Dishes not getting clean or drying completly
I would fill the dishwasher only half full of dishes that are well rinsed off, run the sink water til hot before turning on the dishwasher, use a good quality dishwasher soap or tablet, and make sure the dishwasher is set to a full length setting like potscrubber as opposed to rinse and hold.
Feb 19, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to...
Hi
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Apr 01, 2008 | Dishwashers
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
