Question about Samsung Digimax S630 Digital Camera
Camera lens does'nt go back in the camera.
Light only stays on for a second unless i hold power button, but no picture appears on the screen. Is it ruined?
Meman
  • 3 Answers
SOURCE: Camera Turns Off After 4 Seconds; Lens Won't Retract.
Hi Amber, This is an almost epidemic problem with all brands of digital cameras that have extending zoom lenses. I've had Canons hang before and now my Samsung S500 lens is stuck and camera is beeping in error mode (the kids dropping them you know). Continuing to power on the camera may cause further damage, but you have to face the fact that these cameras sell for $99, so sending it in for service of a very delicate lens assembly is probably going to be a tough call. First make sure you have brand new batteries or a full charge. Sometimes it's this simple. If not, maybe it's just hung and you can gently rock the lens extender as you power on the camera. I've had a lot of success with this method. If the camera takes a lot of hits to the lens assembly, it will eventually strip some of the plastic parts driven by the servo motor. At this point, it's all over; you'll get nothing but some clicking noises as the motor tries to extend the lens and the camera starts beeping in error mode. All is not lost. You can always recover your pictures from the memory card by purchasing a USB card reader from most any electronics retailer. As for the camera, you can try to get it serviced. I'd probably opt for a local service center rather than withering into a skeleton while dealing with the manufacturer. If you know someone handy with a miniature screwdriver, there are dozens of this model camera for sale on ebay for $0.99. Many of them power up and are in great condition except for the LCD screen. You could easily take the LCD screen from yours, transplant it and have a working camera again for 20 bucks or so! Good Luck
Posted on Apr 22, 2007
SOURCE: Camera Wont Turn on
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Posted on Oct 30, 2007
SOURCE: Lens cover stays in between, won't open nor close
Had a similar problem once. Fixed it by opening the camera and freeing up the lens cover.
1)Undo 2 screws each side and the base (6 in all) ignore the one on the front edge of the base for now.
2)Separate the base from the case (gently!) don't pull them too far apart, because they're joined by ribbon cables.
3)Then remove the long screw you ignored above, and again carefully separate the front panel.from the body.
4) At this point, you should be able to access the back of the lens cover, and free up the mechanism.
Once that' s done, put it back together, reversing the above sequence. Don't force anything, just make sure they're all lined up and fit before inserting the screws.
good luck.
Posted on Jun 06, 2008
SOURCE: samsung L730 won't come on...
how about give us our money back!
Posted on Jan 09, 2009
SOURCE: Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Posted on Mar 26, 2009
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
When the camera is turned on with the power button the lens comes out and stays out but the camera immediately shuts off and the lens stays open. The only time the camera remains on is when the dial at the...
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 13, 2009 | Sony Cameras
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Digital Camera Malfunction
its a problem with the iris of ur camera and also sumtimes the CCD .... get it repaired from a repairman
Sep 05, 2008 | Canon PowerShot A70 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Black LCD Screen
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Aug 31, 2006 | Fuji FinePix F601 Zoom Digital Camera
Samsung Digimax S630 Digital Camera Logo
22 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
