Question about RCA F32676SB 32" TV
Rca scenium 62'' hd projection tv
I bought a plasma,had the rca unplugged for about 2 months, and was going to give it away. i turned it on and it comes on fine for about 5 mins, then it will power off and on by itself 2 times, then flash error code 15. it was working fine before i put it away. could it be one of those wonderful cold solder joints rca is known for, or a bad prom?
when id is on i just have a 1080i input on comp1, and all menus and the built in dvd player work fine. pix look just as good as before, with no odd noises. it just wont stal on. i don't know if these tv's have an automatic shutdown that i can bypass. atlease if there is and smoke comes out of it, i'll know where the problem is lol
  • evileddy Jan 10, 2008
    oops sorry for typos
snakehead
  • 1074 Answers
SOURCE: rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Posted on Mar 30, 2007
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
  • 18 Answers
SOURCE: RCA 27r410t 27" won't turn on,just makes high pitch noise
If you are fimniliar with TV fixing you should check its secondary supply may be the H out is short or some thing short there if you have schimatic its much easier to rectify.
Posted on Jun 04, 2007
snakehead
  • 1074 Answers
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
SOURCE: RCA F32665 Shows only gray screen, sound works.
I'm having the same problem. It appears to be some sort of programming issue. Unplug the set for a few minutes, then go through the setup procedure when you plug it back in. This will work for a while, if anyone has a permanent solution please post it.
Posted on Aug 19, 2007
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
RCA Scenium will not turn off an has no picture
Unplug the TV for a minimum of 2 minutes to reset it then try again. If you get no picture there is a possibility the lamp is no good.
Mar 02, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
Sep 21, 2008 | Mitsubishi VS-55609 55" Rear Projection...
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
333 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
