Question about Canon PIXMA iP90 InkJet Printer
Can I use the same installation disk that came with the printer when I installed it for windows xp for my nre windows 7
    Brigadier General:
  • 10,406 Answers
No.
Instead, access the manufacturer's web-site:
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Step 1: select "printers".
Step 2: select "Pixma iP series".
Step 3: select "Pixma IP90"
Click "Go".
Click "Drivers and Downloads".
Select "OS is Windows 7".
Download the appropriate "Guides" and "Manuals", and read them.
Download the appropriate device-driver.
Follow the instructions in the "Easy Setup Instructions" guide.
Posted on Nov 17, 2009
    Problem Solver:
  • 10 Answers
If it is a USB printer you should not need a disk at all, by right as soon as you plug it in windows 7 will go and find the correct driver for your printer. Hope this helps
Testimonial: "Fantastic. Thank you so much for your help."
Upgraded from XP to 7 - paper size and type not showing in select paper window
After upgrading from Windows XP to Windows 7 you probably need to go to the Epson website look up the model printer and download the specific software and drivers for Windows 7 this should correct your problem install that new software
Feb 11, 2018 | Epson Stylus Photo R800 InkJet Printer
The software disk I have will not work on Windows 7
Depending on the Windows version you have, you may be able to use the software. If you have Windows 7 Professional or Windows 7 Ultimate, you can download the Microsft Virtual PC and XP mode and install them on your computer. In so doing you will be able to run Windows XP on top of Windows 7. While running XP you can install that software and run it from XP. You will be able to communicate with Internet, the printers, everything.
Sorry, but you cannot install XP mode on other versions of Windows 7 such as W7 Basic, Home Premium, Just Pro and Ultimate.
Aug 24, 2012 | Pro One Multimedia Spanish
Have lost the printer driver installation disk for my HP psc 2175v all-in-one. need to know how to install without it. thank you!
For Windows XP and such...
Uses this link...
XP Drivers
For Vista and Windows 7 there are no downloadable drivers. Follow this link for instructions to install via Windows Updates.
Windows Updates Install
Aug 24, 2011 | HP PSC 2175 All-In-One InkJet Printer
My brother 7220 will not scan it is saying check cables? I can copy and fax , what am I missing?
Printers usually have a separate driver for scanning and printin.
You might need to install that driver into the pc where you want the scan to come out on. It usually comes out when you insert the install disk.
If you do not have the install disk, just go online to the brother printer website and type in your printer model number usually it will show you the drivers needed to install and instructions to do it.
May 18, 2011 | Brother MFC 5-in-1 Multifunction Laser...
Is Minolta Magicolor 2200DL compatable with Windows 7 if not can it be used with Virtual device XP and if so how is that set up?
Yes it does work with Windows 7. The way to install it is NOt to run the Magicolor install routine supplied with the printer. Insteda in Windows 7 start menu, devices , add printer, clik on the ADD printer option (at the top) . Windows 7 will then come up with a suggested list of printers including the 2200DL. Ignore this as iot only allows a postscript driver to be installed. Instead choose the I have disk option. get windows to look for the install disk (or install files if downloaded from the QMS site and find the .inf file. Click on this. Windows 7 will then install the up to date Windows print engine files and marry it to the dteails for the 2200Dl details and you will end up with a Windows 7 driver. This works in Windows 7 home premium and professional.
Robindtg
Feb 18, 2011 | Minolta magicolor 2200 DeskLaser Printer
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
I installed Windows 7 and my setup disk works only
go to www.hpsupport to get the windows 7 drivers for the printer.
Feb 03, 2010 | Office Equipment & Supplies
I need a 3400 lexmark printer installation disk
Here's the link to the Lexmark driver page for that printer. Choose the correct version for your computer's operating system (ie-Windows XP, Windows Vista, Windows 7). Let me know how you make out.
Jan 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
I have lost the installation disc for lexmark x4690and cant find the driver on the internet
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
Or go straight to driver page for your system:
Driver for Microsoft Windows 2000, XP and Vista.
Driver for Microsoft Windows 7.
Driver for Microsoft Windows 7 x64.
Driver for Microsoft Windows XP x64 and Vista x64.
Driver for Mac OS X 10.6
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then ifyou get in troubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Nov 12, 2009 | Lexmark X4690 Wireless InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
83 people viewed this question
old marine
old marine
