Only top half of screen has picture there is a white line through the centre and bottom half black
    Scholar:
  • 86 Answers
Good day to you friend. you have a vertical problem. when you go into your set the first place you need to look is in the vertical circuits check your size and linear adjustments. be careful because these are sensitive. you want to slowly and carefully do adjustments. check your transistors, bias resistors, diodes, and possibly capacitors. if you cannot find the culprit there, then replace the vertical output ic. thank you for your time and please rate my solution.
Posted on Nov 17, 2009
    Scholar:
  • 53 Answers
If this is a conventional TV with the original style Cathode Ray tube, this fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around £70 ($120), possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it will certainly damage the tube if you leave it running with that white line through the centre!!!
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the white line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Testimonial: "Thanks that sound about right "
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
White screen divided in half with black line
Your ccd imager is defective . You need to replace the ccd imager .You need to contact the service center to get one for your camera .
Jan 30, 2009 | Kodak EasyShare Z700 Digital Camera
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
Dec 07, 2008 | Computers & Internet
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Electro Med Services...
