Question about Samsung DVD-VR330 VCR and DVD Recorder
Samsung dvd sr270m takes an age to 'load', then on-screen message says unable to play or record.10 months old , little used. GEOFF
techman
  • 3130 Answers
SOURCE: samsung dvd-v4600
sounds like you need to clean the laser lens. Try using a disc cleaner first and if that dosent work then take aprt and find the laser lens, take a clean q-tip and put a little alcohol and swab the lens very carefully Good luck
Posted on May 09, 2006
  • 31 Answers
SOURCE: doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Posted on Mar 06, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
SOURCE: Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Posted on Jul 02, 2009
Samsung dvd recorder SH871M has frozen when switched on the dvd draw comes out and wont stop in unable to use any functions on remote control or player i have to isolate from main electrics to stop dvd...
That is one sick puppy. Still young - I would contact Samsung to see if they have a secret code to reset device electronics. Hopefully that will clear the unit's "mind."
Sep 08, 2017 | Samsung DVDHR738 (250GB) DVD Recorder /...
Cannot record whilst watching another channel
It requires two tuners to do what you want. Unless the DVD recorder has a built-in tuner, this is not possible.
Satellite company DVRs can do this because they can have multiple tuners inside them.
Oct 06, 2009 | Samsung Televison & Video
Sony DVD player DVP-NS700H unable to play DVDs.
the dvd player lens damaged. -please change it with good technician
Sep 21, 2009 | Sony DVP-NS700H DVD Player
Player won't read a DVD
Nov 24, 2008 | Samsung DVD-R155
Hi i have just bought a samsung dvd-sr150m of ebay the problem is,i tried to put a to put a new tevion 4.7gb dvd rwto recorder a programme but a message came on the screen unable to record or play this...
Some DVD recorders don't like some types of blank discs. You could have two discs the same but made by different companys and it might only record to one. Also this recorder will only record to - discs eg. DVD-R, DVD-R DL and DVD-RW. Hope this helps.
Aug 16, 2008 | Televison & Video
Cinevision DVD Recorder/VCR does not record.
i am looking for a manual for my cinevision rv 4000 does anyone have one I can buy
Nov 13, 2007 | GoVideo Cinevision RV4000
Samsung DVD-R130 will not load dvds, but will play CDs
I just filed a complaint with Better Business Bureau against Samsung. Would anyone be interested in joining me in the complaint?
Nov 09, 2007 | Samsung DVD-R130 DVD Recorder
Unable to record/dvd recorder problems mwr20v6 phillips
I also have same problem and have had no luck with anything I have tried
Aug 11, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD playback
Samsung dvd players are known for bad spin motors. You may try to clean the laser and see if that changes the disposition of the problem. If there is no change and with the top of the unit off,if you see the pin point of laser on top of the disc, and the disc moves or shivers, the chances are it is a bad spin motor. In most cases, it is not cost effective to replace the motor. If an auxillary line in jackis available , buy a $30 dvd to replace it rather than taking it to a service facility that will charge you the same amount to evaluate it. Scrivitron
Jun 15, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Samsung DVD-VR330 VCR and DVD Recorder Logo
Jerry Greenberg
Jerry Greenberg
