Question about Audiofonics ADF-241 Car Audio Amplifier
Audiofonics amp i have a 800 watt audiofonics amp hooked up to two kenwood tens, but only one speaker plays. i switch the speaker wires around and the oppisite speaker plays. what wouold be that problem? but when i bridge the speakers they both work , but i don't want to do that because there is not enough power.
  • 631 Answers
Reconnect one speaker per channel and swap the RCA cables (L > R and R > L) to see if the working channel switches sides. If not, move all switches and controls to see if any are intermittent.
Posted on Jan 11, 2008
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
One is broken
Does it smell funny?Smell around the top of the magnet and see if it smells like burnt plastic.If it does then the voice coils are burnt.Push down in the center of the sub if it dont move at all or has a grind the the voice coils are burnt up.Look at the lead going from the wire hook ups to the speaker cone are the intact?If not thats your problem.
Jun 18, 2009 | Audiofonics ADF-272 Car Speaker
Amp Turns off after 30 seconds of song play
Since the unit recovers once it has powered down. I suspect that the internal protection circuit is kicking in. Check the wiring and be sure that there are no crossed wires anywhere. These amps are designed to work with 2 ohm loads and can take a direct short for a short period of time. If the wires appear ok, measure the speakers with an ohm meter. If the speakers are 4 ohm rated, they should measure just under 3 ohms with the meter, If they measure less than 2 ohms, there is a problem with the speakers.
Also, does the amp shutdown regardless of the volume level or just when played loud?
Thanks,
Dan
Apr 15, 2009 | Kenwood 1000W Class D Bridgeable Mono...
Need to hook up to a 4000 watt amp
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Apr 13, 2009 | Theater Research TR-9500 Car Subwoofer Box...
RIGHT HAND SPEAKER, DISTORTION.
First switch the speakers over to make certain it is not the amp that is the problem.
If the speaker is still playing up on the other channel, then I would look around at a new set of speakers. They can be any that you like the look of as long as they have a power ratting at 40 watts or above each. The amp says it can take 6 to 16 ohm speakers. I would go for 8 ohms as they are more common.
Jul 03, 2017 | Kenwood NV-600 CD Shelf System
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
Feb 10, 2008 | Audiofonics ADF-272 Car Speaker
ADF-243 Amp
What you need to do, is also run the rca cable from the back of the deck to the amp. The speakers are already powered by the deck. You can then hook up your subwoofers. The switches are for your own taste.. you adjust them as you go.
Jan 30, 2008 | Audiofonics ADF-243 Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Audiofonics ADF-241 Car Audio Amplifier Logo
123 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
