Question about Empire GWT-25 Wall Mounted Panel Heater
My propane furnace sounds like a blowtorch when it kicks on but it also happens to my cooking stove
    President:
  • 1,515 Answers
Hi, working with natural gas and converting them over to propane for the country folk, I do indeed know the sound. You might want to take a look at the burner section for any signs of carbon,soot, build up any where.If the gas pressure has changed for some reason, you will get this blow torch sound.You would need the correct meter to check or measure the inches of W.C. Inlet pressure not to exceed 1/2p.s.I. Outlet for propane has changed over the last 10 years, you will now find on the MGV (main gas valve) for propane is almost the same as with natural gas.W.C. is a measurement used in reading gas pressures, stands for inches of water-column. Recommended pressures are well marked in manuals and on valve its self. Right at 2.5 to 4" w.c. So, check for carbon build up and clean if needed.If it burns radical, pressures should be checked with a gas pressure test kit.Yellow Jacket makes a good one. I hope this has been of some help to you, Sincerely,
Shastalaker7
Posted on Nov 17, 2009
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Need parts
If there is no nearby repair dept, try Colemn.
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
What are the different kinds of propane stoves?
There are three kinds of propane stoves: single burners, double burners, and multi-cookers. Single burners are the cheapest as they only allow you to cook/boil one thing at a time. Double burners allow you to prepare two meals at once, and finally, multi-cookers enable you to prepare multiple meals at a time.
Oct 25, 2012 | Camping, Backpacking & Hiking
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
My Coleman propane furnace kicks out once and a wile and flashes a 10 flash code (gas flow with no call for heat) what need to be fixed the furnace is only 1 year old.
This sounds like you have an intermittent main board problem. It may be turning on you furnace when the thermostat is not calling for heat. It also could be a short in your low voltage(thermostat wire) going to your furnace. Either way you need to have it checked. It's under a year it should still be under warranty.
Jan 23, 2011 | Coleman Propane Forced Air Heater...
Hello. I just moved into an apt. with a Charmglow Propane Stove..Model # CGL250TE. Do I need any ventilation precautions with this stove??
Hi, any gas range or oven does not need to be vented to the outside. The reason is that this not a heating device and is meant to be used for short periods while preparing meals. People get into trouble when they try to heat the apartment by running the oven all night. If you happen to be cooking for an extended period, you may see extra condensation on the windows but opening the window a crack will help. Of course if you smell propane when your not using the stove, that would indicate a leak and should be taken care of.
Jan 12, 2010 | Williams 2509612 Ceramic Mid-Size Heater
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Heating & Cooling Logo
582 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
