Question about ASUS P4P800-X Pentium Motherboard
I have a p4s8000-x sitting in front of me and i'm wondering where the power switch orange and white cable plugs into the motherboard
  • bbarnett144 Nov 17, 2009
    Thanks Ichand1958,
    The power is on, I'm getting a green light on the motherboard. When I turn the power on, the fan jumps for a millisecond and then that's it. Nothing happens,no boot, nothing...I wonder if it's the motherboard?
    President:
  • 1,146 Answers
Hi:
With the motherboard in front of you, and the connectors facing away from you, there is a small header, or set of male pins on the left corner, closest to you. Often there is a screened on map or writing as to what pins do what, but if you can't find that, download the manual from the ASUS website.
Posted on Nov 17, 2009
Alert! alert front i/o cable failure in Dell Optiplex 390
unplug the orange cable on the motherboard leading to the dvd-rom and replug it into any of the next available slots(2 or 3).
one of them is white in colour and you have to look closely to see the numberings.
problem is sloved.enjoy.
Aug 16, 2013 | Computers & Internet
Fix wireing on p6610f
George,
This solution will be long in length. Therefore a lot of reading.
In essence I am typing out a motherboard manual, of a sort.
May look complicated. This is because I get very detailed.
If there is ANY area I have explained, that you do not fully understand, please post back in a Comment.
I will try to break it down, and/or use a different method of explaining.
1) Let's start with power cables from Power Supply, to motherboard;
HP Support > Pavilion p6610f Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=4299342
Product information > Product specifications > Motherboard Specifications, N-Alvorix-RS880-uATX (Alvorix),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02560084&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4299342#N64
Looking at the photo of the motherboard, it is 90 degrees to the LEFT; in comparison to how it actually is mounted in your computer case.
(BTX form factor motherboard, and computer case)
I would also like you to scroll down, towards the bottom of the page; and look at the illustration of the motherboard.
(Motherboard Layout)
This way we can compare the two together, as I guide you.
A) At the bottom of the motherboard is the connector, for the 24-pin ATX main power cable.
Yellow/White in color, 24 socket holes. (2 rows of 12)
This is a General example of said power cable, and respective connector on motherboard;
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[Note* Color of power cable connector, and motherboard connector; does NOT matter ]
In relationship to how it actually sits on the motherboard, while mounted in Your computer case; you will find it all the way to the LEFT.
Note the Lock Clip on the power cable's connector.
Has a hooked end that goes over a TAB, on the motherboard connector.
When deemed to be plugged in tightly, and correctly; the hooked end will be Over the Tab.
Operates on the same principle as a see-saw on a playground.
Squeeze the top in, to release when disconnecting.
B) 4-pin ATX +12 Volt power cable.
Yellow/White 4-socket hole connector. In the photo, above the processor socket, and to the Right of the square Aluminum finned Heatsink.
You will find it to the Right of the processor, and Below the aluminum finned Heatsink; motherboard mounted in computer case.
General example of said power cable, and respective motherboard connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note Lock and Tab design, just like the 24-pin ATX main power cable.
Power for the Processor (CPU)
PU521 on Motherboard Layout.
That's it for power cables TO motherboard.
2) The front of your computer is the Front Panel.
[Regressing;
Header; Rectangular small piece of plastic, that has contact pins sticking up.
You have 3 Black headers on the motherboard, a Yellow header (1), and 2 White headers.
This will become more self-explanatory, as we go on ]
To the Left of the 24-pin ATX main power cable's, motherboard connector; and to the Left of the ram memory slots; are three Black headers. (Photo)
(Mounted in computer case, To the Left/Top of motherboard)
The Orange connector you see to the left of the ram memory slots, is a SATA connector.
Looking at the Motherboard Layout, you will see it is SATA4.
To the Immediate RIGHT of it, is the Front Panel header.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Main wires such as Power On switch, Power On LED light, Harddrive activity LED light; and Reset switch.
On the Motherboard Layout, it is marked as J18.
You should have a cable coming from the Front Panel, whose plug on connector; matches this header.
Has 9 socket holes. 5 on one side, 4 on the other.
The missing pin in the corner, on the Front Panel header on motherboard; shows you which way the cable's plug connector, goes.
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
3) I do not know sir, what the long black header is to the left, of the Orange SATA4 connector, is. It is P17.
However looking at the length, you should find only ONE cable, and plug on connector; that matches it.
Should come from Front Panel. (IF it is used)
4) I do not know what the black header is, below J18.
(Again, J18 is the Front Panel header)
I believe with process of elimination, that the cable that goes to this header, will become readily apparent. (IF it is used)
5) There are Four SATA connectors on the motherboard.
SATA1 = Dark Blue
SATA2 = White
SATA3 = Light Blue
SATA4 = Orange
(Photo. Also compare in Motherboard Layout)
This is where a SATA data cable plugs in.
Your harddrive is a SATA unit. Your optical drive (CD/DVD drive) is a SATA unit.
The Harddrive plugs into SATA1.
The optical drive plugs into SATA2.
Any additional SATA units will plug into SATA3, or SATA4.
Example; A second SATA optical drive.
This is a general example of a SATA data cable, and SATA data connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the SATA data cable connector. Has an L-shaped opening.
When connecting the SATA data cable to Harddrive, or optical drive;
Turn this L to the Left, and upside down. The 'foot' of the L always points DOWN.
Note the SATA data connector example shown. This is an OPEN design. Your SATA data cable connectors on motherboard, are a CLOSED design. Still has L-shape on motherboard connector, though.
The SATA data cable connector that goes to the Harddrive, and optical drive; is usually a 90 degree bent elbow.
NOT always though.
The SATA data cable connector that goes TO the motherboard, is a Straight connector.
Between a SATA data cable connector, and a SATA power cable connector; a SATA data cable connector is Shorter in width.
SATA data cable connector has 7-pins.
SATA power cable has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Same L-shaped interface is used.
Most of the time there is a Lock, on the SATA power cable connector. May be a Tab that sticks up, or a small lever, or a rubber 'bulb'. Depress with thumb to connect, or disconnect.
USB headers on motherboard, and USB connectors on motherboard.
Continued in added Comment.
Regards,
joecoolvette
Mar 23, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
P6610f motherboard
Are you following Anti-Static Procedures?
If you, or the person who took it apart has not, you can use the motherboard for a Frisbee.
(Processor for a neck trinket, and Ram Memory for Christmas decorations)
Moving on.........
A) Let's start with the two power cables coming from the Power Supply, that go to the motherboard;
1) 24-pin ATX main power cable
Looking at the motherboard photo, the 24-pin ATX main power cable's connector; is at the bottom.
Two rows of 12 socket holes, in a yellowish/whitish connector.
Motherboard installed in computer case, you will find it to the Right.
(The motherboard view shown, is clocked 90 degrees to the Right; in comparison to how it actually sits in the computer case)
GENERAL example,
[NOTE* Color of connector does NOT matter ]
Note the hinged Lock Clip on the power cable's connector.
Also the TAB on the motherboard connector.
When power cable is deemed to be plugged in tightly, and properly; the Lock Clip will be over the Tab.
{Lock Clip operates on the same principle, as a see-saw on a playground. Top is squeezed in to release Lock Clip}
2) 4-pin ATX +12 Volt power cable
Looking at the motherboard photo, the motherboard connector for this power cable is;
Straight up from the white Processor socket,
To the right of the square finned Aluminum Heatsink.
General example of said power cable, and it's respective connector on the motherboard,
Has a Lock Clip too.
Remember about the color of connector, thing.
Can be pink with neon polka dots. Doesn't matter.
WHAT the power cable IS, does matter.
This power cable is power for the Processor.
It ain't plugged in, you have no computer.
(Scroll down to Motherboard Layout. It is PU521 )
That's it for power cables that plug into the motherboard.
Moving on..........
The Harddrive is a SATA unit. The optical drive is a SATA unit.
(CD/DVD drive)
Means you need a SATA power cable for each one of them.
General example,
Note the L-shaped opening in the connector. Hard to see in this photo, but I will show a better view in a minute.
Also; between a SATA data cable's connector, and a SATA power cable's connector; the SATA power cable connector is the larger of the two.
Has 15 contact pins.
Often there is a lock on this power cable's connector.
A tab that sticks up, or a 'bulb' type affair.
Depress with thumb, when plugging in, or unplugging.
Harddrive needs a power cable, and data cable.
So does optical drive/s.
B) General example of a SATA data cable, and it's respective connector,
Just referring to the cable shown at the top, for now.
Now you can see the L-shaped opening a little better.
See how the 'foot' of the L goes down? That is the direction you want it, when plugging in.
The motherboard connector shown below the SATA data cable, is a SATA connector.
This particular style is OPEN.
Your motherboard uses the type that is CLOSED.
Note also the L shape on the motherboard connector.
The connector shown for that SATA data cable, is a 90 degree bent elbow.
If your SATA data cables have this style of connector, they plug into the Harddrive, and optical drive/s.
The straight type of connector, plugs into the motherboard.
It can also plug into the Harddrive, and optical drive; if your SATA data cable has two straight connectors.
The SATA data cable connectors on your motherboard, are all the way to the Left. (In the motherboard photo)
Orange, Light Blue, Dark Blue, and White.
Note that they have a L shape in the middle.
Now scroll down the HP Support page, to Motherboard Layout.
Orange = SATA4
Dark Blue = SATA1
Light Blue = SATA3
White = SATA2
SATA1 is for the Harddrive
SATA2 is for an optical drive.
If you have more than 1 optical drive, it plugs into SATA3.
(Make sure SATA3 is ENABLED in BIOS Setup)
C) The front of your computer is the Front Panel.
Looking at the motherboard photo, look again at the Orange SATA4 connector. To the Immediate RIGHT is the Front Panel header,
I believe though, that the cable coming from the Front Panel; has one solid plug-on connector. Not individual wires.
Note how the Front Panel header on the motherboard, is missing one pin. This is the Key.
The cable connector going to it, should have one socket hole blocked off.
Should only be one cable coming from the Front Panel, that has the correct plug-on connector.
The other cables coming from the Front Panel, will have different size plug-on connectors.
Going further.........
Look at what is installed in the Front Panel;
USB ports, audio ports, (Headphone and Microphone), Card Reader, etc.
You can follow the cables, and get a pretty good idea of where they go, in the Front Panel.
For example you can follow the cables that go to the USB ports.
Follow the two cables that go to the Card Reader.
Follow the cables that go to Microphone, and Headphone jacks.
Then by process of elimination, you know which cable goes to the Front Panel header.
D) Front Audio
Looking at the motherboard photo, look towards the Top/Left corner.
The Yellow header is for the Front Panel audio ports.
Headphone, and Microphone.
E) Coming down the Left side, in the motherboard photo; look at the two White rectangular headers.
Match up in the Motherboard Layout, and bottom of HP Support page.
USB1 2, and USB1 2.
EACH USB header, is for TWO USB ports.
That is why they both have USB1 2 marked near them, in Motherboard Layout.
A Card Reader SHOULD use two cables, and One USB header.
It may be though, that the Card Reader will use both of those White USB headers.
Either the Card Reader plugs into them, or the USB ports in the Front Panel.
If the cable connector fits, plug that cable in. (On)
USB is USB.
Card Reader uses USB too.
Point?
If the cable's connector fits, plug it in. (On)
In the motherboard photo, there are two White connectors;
Above the Orange SATA4 connector, and Below the Light Blue, and White SATA connectors.
(Light Blue = SATA3, White = SATA2)
The USB ports up front probably connect to them. (Front Panel)
Follow the cables to Front Panel USB ports.
What type of connector do the cables use?
All FOUR of those USB connectors on the motherboard, may NOT be used.
Perhaps just two of them.
That doesn't 'sound' very concise, huh?
However it is my contention, that each cable coming from the Front Panel; should have a different connector.
Going further;
The Card Reader, and the USB ports in the Front Panel; may have the SAME type of connector, on the end of their cables.
Again, the Card Reader uses a USB header, (Or headers), on the motherboard.
So do the two USB ports in the Front Panel.
Therefore it does not matter which USB header on the motherboard, that either one of them are connected to.
F) Looking at the motherboard photo, look above the Ram Memory slots, to the far Right.
Right above ram memory Slot 1, that is White in color. (DIMM 1)
There is a small Electrolytic Capacitor, with a Black plastic sleeve.
Right above it is a small White 3-pin connector.
This is where the Processor fan plugs in.
(CPU_FAN)
G) Right above the square Aluminum finned Heatsink, is the 3-pin connector for the computer case fan.
SYS_FAN
(System Fan)
(The square Aluminum finned Heatsink, sits on the Northbridge chip.
Which is part of the motherboard chipset)
That about does it for me.
Please post additional questions in a Comment.
Regards,
joecoolvette
[Seems like I gave a solution for this before.
I can't pull it up in Solutions I have given, so do not know for sure.
Want to see someones user account?
If you are a member of FixYa, all you have to do is click on their user name (Example; joecoolvette), or user icon ]
Mcp61sm-am motherboard manuel needed
Ya know Acer owns Gateway now,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
A) Power Supply to motherboard cabling;
http://www.ebay.com/itm/ECS-MCP61SM-AM-V-1-0A-SOCKET-AM2-AMD-MOTHERBOARD-uATX-/290606277901
Scroll down to the motherboard top view photo.
Product Views > Hardware Details
1) 24-pin ATX main power cable. (S - Main Power Connector)
This is a general example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
[Note color of connectors does NOT matter ]
Note the Lock on the side of the main power cable's connector, and the matching Tab on the motherboard connector. When properly plugged in, the hooked end of the Lock will be over the Tab, on the motherboard connector.
In the photo of the motherboard shown on the Ebay link, this connector is on the Right side of the motherboard, next to the blue IDE (PATA) connector.
2) 4-pin ATX +12 Volt power cable; (F - Auxiliary 12V ATX Connector)
General example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
In the motherboard photo; Small square 4-socket hole connector, to the Bottom/Left corner of the Processor socket.
This power cable's connector also has a Lock, and the motherboard connector has a Tab.
That's all the power cables that go to the motherboard.
B) With 2 SATA headers (Connectors) on the motherboard, and one IDE (PATA) connector, it suggests to me that this motherboard is set up to use a SATA harddrive.
This is a general example of a SATA power cable,
Note that it has 15 contact pins, and between it, and the SATA data cable connector, it is the larger of the two.
There is a Lock tab on the connector that you depress, to install, or remove the cable.
You can use a SATA optical drive (CD/DVD drive), or an IDE (PATA) optical drive.
An IDE (PATA) optical drive uses a standard 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ Misnomered as a 'Molex' power cable. Molex was the first to make the power cable's connector. Name stuck, kind of like calling an open-end wrench a Crescent wrench ]
A SATA data cable is used for the SATA harddrive. The connector end that goes to the Harddrive, is usually a 90 degree bent elbow.
The straight end plugs into the motherboard,
General example of a SATA data cable, and it's corresponding connector on the motherboard,
Note the L-shape in the inside of the SATA data cable's connector, and the L-shape on the motherboard connector. They line up.
The SATA power cable also has this L-shape.
In Hardware Details click on -> Q - SATA Connectors
The Bottom one, or one closest to the outside edge of the motherboard, is SATA1.
Although it isn't marked on the motherboard, or at least not visible in this photo, SATA 4 is. Look at the top where a SATA 4 connector would be.
The SATA harddrive should be plugged into the SATA1 header.
(Connector)
HOWEVER, the beauty of SATA is that it does NOT matter, which SATA header on the motherboard, you plug the SATA harddrive into.
BIOS will find it.
(Supposed to be SATA harddrive to SATA1, and a SATA optical drive to SATA2)
In the motherboard photo on Ebay, they are Orange in color, and under the blue IDE (PATA) connector.
C) Going from Hardware Details and the Ebay motherboard photo;
B - CPU Fan 1 Connector, is where the Processor fan plugs in.
In the motherboard photo, there are 7 cylindrical Electrolytic Capacitors in a row, to the left of the processor socket.
This connector is located immediately above the top capacitor, near the outside edge of the motherboard. (Brown in color)
E - Floppy Disk Connector, is above the white 24-pin ATX main power cable's connector, and the blue IDE (PATA) connector. It is Yellowish in color. (34 pins)
G - System Fan Connector, is white in color, has 3 contact pins, and is located under the white, square 4-pin ATX +12 Volt power cable connector. This is where the computer case fan plugs in.
I - PCI Express x16 Connector, is Orange in color, and below the processor socket. It has PCI Express silkscreened on the motherboard immediately below it.
This where a graphics card, and ONLY a graphics card, is installed.
J - PCI Express x1 Connector, is white in color, and immediately below the orange PCI Express x16 connector.
This is NOT used for a graphics card.
Whatever you can use in a PCI slot, except a graphics card, can be used in this slot; -> Provided it is a PCI Express x1 card.
(Ethernet Card, Sound Card, etc)
L - CD-in Connector is where the audio cable from the Main (Primary) optical drive goes to.
Ya got me on this one. I know it's located real close to the Realtek audio chipset, and I think that is to the left of the orange PCI Express x16 slot.
M - Front Audio Connector, is where the front audio (Sound) ports, of the Front Panel connect to.
Green in color, and located under the bottom white long PCI slot, and near the outside edge of the motherboard.
N - Clear CMOS Jumper is self explanatory. It is located under the finned Heatsink, (Looks like a meat tenderizer), of the Southbridge chip.
(Which is located under the Ram Memory slots)
O - USB Connectors are Yellow in color, and located under the finned Heatsink of the Southbridge chip, and towards the outside edge of the motherboard. (Or also located under the Ram Memory slots)
P - Front Panel Connector, is located at the Bottom/Right corner of the motherboard, close to the 'Buzzer'. (Buzzer is used for BIOS Beep Codes) PANEL1
4 pins on the Left side, 5 pins on the Right side.
The pins on the Left side are numbered EVEN.
The pins on the Right side are numbered ODD.
Starting on the Bottom of the Left side going Up;
Pins 2, 4, 6, 8, and 10.
Starting on the Bottom of the Right side going Up;
Pins 1, 3, 5, and 7
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch. IF a Reset switch is used.
C) Pin 9 is Not Connected. Used by the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
More to follow.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Acer Aspire™ T180 PC Desktop
Front panel connectors
Black or white is negative, color is positive. Pin 1 is usually positive.
Also, If you look closely at the plastic plug, there *should* be a tiny triangle/arrow....that's the "+".
May 18, 2012 | Computers & Internet
I unplugged the little cables in the F_PANEL to the right bottom in my GIGABYTE GA-G41M-COMBO motherboard and the CPU is working after i reconnected them the but nothing appears on the monitor i hear the...
The problem most likely isn't with your f_panel your motherboard should have a manual that tells you how to plug everything into your f_panel correctly.
Ensure that there are no empty power connections on your motherboard. You board may not be powering its video component. If you have a graphics card, ensure if it requires a power connect that it is properly plugged in.
If this doesn't work I suggest your return your motherboard as it is not functioning properly.
Jun 17, 2011 | Gigabyte GA-G41M-Combo Motherboard
I need assistance with the front panel cables (Power, HDD, Reset etc)
On your motherboard power is setup like so:
10 9 8 7 6 (no pin on 6)
1 2 3 4 5
1- HD_LED_P
2- HD_LED_N
3- RST_SW_N
4- RST_SW_P
5- RSVD
6- No pin
7- PWR_SW_N
8- PWR_SW_P
9- FP PWR/SLP
10- FP PWR/SLP
you have 5 connectors from the chassis' front (with cable colors):
-P LED (white)
+P LED (green)
HDD LED (yellow/white)
RESET (white/blue)
POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
Regards
Ashly
Feb 24, 2010 | Computers & Internet
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
Prescott 533 mother board power up conections to front switch
I am looking for the connection of the power button to the motherboard. Somebody plugged it out and thought it was a single plug. Now I sit with 5 plugs and do not know where to put them back and how to jump the reset.
Mar 08, 2008 | Computers & Internet
Front Panel Connection Problem
if you look at the PDF file here:
ftp://download.intel.com/support/motherboards/desktop/d845hv/A6513601.pdf
On page 68 you can see it more clearly. Just enlarge the file.
do you know the make and model of the case?
Nov 20, 2007 | Intel D845HV (735858149143) Motherboard
ASUS P4P800-X Pentium Motherboard Logo
448 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
