Question about Vivitar ViviCam-X30 Digital Camera
Cant close the objektive/lens doesnt shut by it self just stay open all the time,
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Everytime i turn my camera on the lens open and shut.
you have dameged the mechanism and the lens may be like a cross threded screw that is why it closes down. it is expensive to repair via Canon.
so try this.. close the lens by turning camera off take the camera and slap it into the palm of your hand 2/3 times then turn back on. this should put it back in its aligned track. if it doesnt work the foirst time try to about 20 tijmes if it still dosnt work its a throw away or a big outlay
Jun 23, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
Jun 22, 2008 | Microsoft Xbox 360 Console
Lens wont close!
goto www.digitalcamrepair.com for help their is a self diagnosis page.
May 28, 2008 | Casio Exilim EXZ75 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
The slide doesnt open
Contact this site as theres as well a toll free Tele # Good Luck http://www.nikoncamerarepair.com/
Apr 09, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Vivitar ViviCam-X30 Digital Camera Logo
20 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
