Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator I have a whirlpool ultimate care ll. In August of 2006 I had to have sears come out and repair the washer. The problem then was that the agitator would wash the clothes but it would not spin. The other day I noticed the agitaor will move clockwise and occasionally counterclockwise. Does this mean that there is a problem. I am afraid that the agitator is going to stop working. If it is a problem how do you fix it.
  • donkell Jan 10, 2008
    The thing is I don't think the agitator is moving correctly during the
    wash cycle. Should it go all around, the bigger the load the less it
    moves. You can hear the noise it makes but i don't think it moves as
    freely with larger loads.
    Thanks!!! Maybe I need to just go to bed and quit obsessing about the washer machine. Kelly
    President:
  • 1,314 Answers
The agitator is supposed to do that in wash dont worry
Posted on Jan 10, 2008
  • robert samples Jan 10, 2008
    the agitator goes back and forth if it went all the way around it would slosh water out of the tub if its getting your clothes clean its doing its job the agitator has nothing to do with a no spin condition if it quits working contact me here before calling for repairing and ill be happy to asst you to make sure your doing the right thing ok
    yep if its not broke you dont have to fix it but feel free to consult me any time
6ya staff
SOURCE:
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you disassemble the agitator for a whirlpool ultimate care ii?
i am assuming that you want to do that to replace the agitator dogs? this vidoe will show ya how to remove the agitator and replace the dogs.......http://www.youtube.com/embed/0GQh8JLqVv8" frameborder="0" allowfullscreen>
Jul 18, 2011 | Whirlpool Ultimate Care II GSW9650LW Top...
Bottom agitator spins but the top piece is loose like something is missing. The top piece of the agitator and the soap despensor just come right of and spin freely... there is nothing holding it on. Looks...
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs on the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3094543 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i remove the agitator on my whirlpool ultimate care II top loader washer
first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont agitate
your dog ears are bad.
You can replace them for about $10 @ your local appliance store.
Aug 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II washer that had developed a "wrap" sound coming from the agitator. The agitator had a loose fit at the top, and can be moved about a 1/4 inch from side to side. How do I...
Remove the fabric softner cup. Remove cover underneath it by pulling up on it. It just snaps in and has a seal on it. Remove the bolt and lift up the upper agitator. You will need to get an agitator repair kit from an appliance parts store. It has seals for bolt and cap,.thrust washer for the botttom of upper agitator , cam dogs and a new holder and plate. Be sure to take the model number with you.
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool ultimate care 2 washer works great, however, the agitator misses and clicks before it catches up
Is this a two piece agitator? You may just need dogs, they are inside the agitator. Rotate the top of the agitator back and forth, top should engage the bottom portion when turning counter clockwise.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
153 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
