Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My wireless modem is e960
Some one put a password on my wireless modem e960. eventhought i type admin on the password i can't enter into the 192.168.1.1
  • 532 Answers
If there is a reset hole at the back insert a small paperclip into the hole and hold it for 30 seconds.
If not try this from a command prompt
First enter the command erase mtd5 (Enter), then reboot (Enter), which will reset the router to its factory default state.
Posted on Nov 17, 2009
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
How do i set up a password
Open Browser ( Firefox, internet explorer, ext)
type your computers IP address where you would normally type the web address, press enter.
your router settings should now come up but you need to enter a username and password before you can make changes.
try using user name (admin) and password (admin).
now look for the security tab and edit as needed.
Nov 23, 2012 | ASUS DSL-N10 Wireless-N ADSL Modem Router
Lost password for router
if this your own modem then connect through Ethernet port via a straight cable. most of linksys modems has configuration page IP is 192.168.1.1
1. type this in your web browser and go
2. login is required, enter admin,admin as username,password
3.if admin,admin does not work you may see it in the given manuals
4. once you ar in the config. page go to wireless settings, security.
5. you should be able to see "pre-shared key" if it is star hidden, you may type a new one and save configuration.
i will be happy to assist more if this donot solve your problem.
Aug 09, 2012 | Linksys WRT160N Wireless Router
Hello I would like for my wii console to connect wirelessly onlne to enable my netflix to be connected andveiwed. I am in need of the correct wep/wpa access key. What is the best way for me to locate this...
If there is one already set up by default, it might be located on a sticker below your router/modem/box. And you will definitely find it in the configuration of the router/modem/box, via it's web interface
To access to the configuration page of your router/modem/box, type it's address in your favorite web browser. If it asks for a username and a password, type either "admin" "admin", "admin" "password" "admin" then blank, or both blank. If none of these are accepted, refer to the manual to get the proper login.
Then, in the wireless settings section, there might be a default wep/wpa key. You can change it, or create one if it's not present. I would recommend creating a WPA PSK password
Once all this is done, you can then go back to the Wii and start the process for the wireless connection wizard. you then enter the key you have retrieved/created on the router/modem/box and you are done.
Enjoy !
Apr 26, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I want to secure my internet
  1. Follow these steps to configure Linksys WRT160N wireless router.
    1.Open Internet Explorer, it does not matter if you see error message such as "The page can not be displayed" . now erase everything on the address bar and type in this IP address: 192.168.1.1 or the full address: http://192.168.1.1This is the default IP address for the router set by Linksys.
  2. 2 Hit the Enter key on your keyboard to connect to the router's web admin control panel. You will be prompted a login window for the username and password: the default admin username is "admin" and the default admin password is "password". If you can't connect to this admin control panel, you will need to change the IP address on your modem, maybe your modem is using the same IP 192.168.1.1 also, just unplug the router from your modem, and hook up your computer directly to the modem and fire up the web browser and enter the IP 192.168.1.1 and follow the on screen direction to get in.
  3. 3 It will then ask you to change password, then you make up a password that is meaningful for you to remember. You will need to write down the username and password for future reference because I am sure you will forget. You will need to reset the router if you forget the router password, and that will erase everything saved inside the router setting.
  4. 4 After successfully login, you will be in the Basic Setup of your Linksys WRT160 wireless router. You also might need to clone the Mac Address if you are using Cable Broadband (Comcast), to do this go to Mac address clone -> Enable, then clone my computers Mac.
  5. 5 If you are using Verizon, you might need to change the Internet Connection Type to PPPoE and enter your username and password that is created by Verizon.
  6. 6 I think many of you concern more on the Wireless secrutiy. Click the Wireless tab and enable the wireless security, you will need to choose a type of security encryption, WEP is weaker, you will need to type 10 characters for the pass code. The WPA or WPA2 is much stronger that it takes passphrase. For more security on wireless connection, you can also try to use MAC authentication, each of your laptop or wireless card has unique MAC address, you find out the MAC address on your laptop then enter it into your router so only this laptop can have access to the wireless connection.
Jan 25, 2011 | Linksys WRT160N Wireless Router
Lost wireless connection
I would like to set up a password but dont know how to go about it
Connectcable modem to PC / laptop start web browser and enter IP address (like 192.168.1.1.) ofmodem, log in with admin / admin now you are in menu of modem securityand go to fill in what you want as password
save it and if you want make connection to the net you have to fill in the paswoord you put in
on the back or botem are a small hole this wil reset the modem and login paswoord
Nov 01, 2009 | D-Link AirPlus DI-524 Wireless Router
I have BSNL broadband with Siemens SL_2 141 modem provided by BSNL. I want to connect it wireless with my desktop. I also have a Netgear WG111 v3 USB adapter. Please suggest how to install the wireless...
First get IP of Siemens SL_2 141, start- run -cmd- ipconfig /all
Note down Default Gateway IP address ( Generally 192.168.1.1)
Type it in Internet Explorer address bar and hit enter
put username admin, pass admin
Click Wirelles then in Basic setup, Enable Wireless, Enter SSID as BSNL, transmission mode 802.11g, then remaining option as auto, do not keep security now let it be disabled, click apply or save and rebot the router.
Install Netgear software in ur desktop let search for ssid BSNL and connect automatically. Once connection gets establish then set security WEP-PSK and put password also in Netgear u have to mention same password whil connecting.
More help here page no 97
any query revert,
Thanks
Sep 05, 2009 | Computers & Internet
Connecting a thomson speedtouch 858v6 modem to wireless
open the web browser, type in "10.0.0.138" without the quote in the address bar, press enter. that should bring you the the log in screen of the speed touch.
type in "admin" with password of "SpeedTouch" S and T are capped.
to configure the DSL go to the following link and select the configuration you are look for.
http://www.grandecom.net/site-file.php?fid=37
Jan 29, 2009 | Alcatel Speed Touch Home Modem
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
244 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
