Question about BUFFALO ACDelco 6500 Watt Generator Electric Start
My onan generator voltage is around 127 to 129 volts but wont run a space heater what is the problem i changed the fuel filters
    President:
  • 3,433 Answers
First thing you need to do is turn down the engine speed and get the voltage dow to max 120v, Then chk the heater. Excessive voltage will ruin appliances. .
Posted on Nov 18, 2009
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Need to know what the volts should be on the starter side of solinoid on a onan 4.0bfa r.v. gen.
Typically near full battery voltage. During starting this may fall to around 10 volts due to the high current once the starter motor engages.
Oct 31, 2011 | Watts Onan Portable Generator - 4000 ,...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Wont keep running after start button is released
If the fuel filter is good and lines are good then it sounds like the fuel is making its way to the carb built trash is stopping the fuel from getting into the engine in order to run. Clean out the carb bowl and clean out the valve stem. I know on the Honda unit the valve stem is removed with the carb bowl then then with a striaght screw driver you can remove the Body once you drop the bowl down with the stem so to clean out the cyclinderical body. Good luck
Jul 28, 2009 | Watts Onan Portable Generator - 4000 ,...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Try to restart to see what happens. However, make sure to have a volt meter to check output voltage. You may be loosing voltage and therefore it shuts down. Check oil pressure switch, rings, brushes. Replace brushes if they are less than 1/2" short and clean rings with emory cloth until copper is noticable.
Jan 21, 2009 | Watts Onan Portable Generator - 4000 ,...
BUFFALO ACDelco 6500 Watt Generator Electric Start Logo
82 people viewed this question
Top BUFFALO Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a BUFFALO Electrical Supply Expert? Answer questions, earn points and help others
