Question about Panasonic CT-20G4 TV
My picture on my Tv is one scrunched up line across the set
    Scholar:
  • 63 Answers
The vertical output circuit has a failure. Very likely the vertical output i.c. and perhaps some small related components. These parts are soldered in place on the main board. If you are technically inclined and able to solder you should, with a schematic & digital multimeter, be able to fix it. Otherwise locate a competent technician or consider a new unit. I wish I always had good news and a quick fix, but my car mechanic usually can't do that for me enither. Good luck.
Posted on Nov 17, 2009
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Televison & Video
Tv comes on and then after a while the picture goes down to this scrunched up color lines in the middle of the set and sound goes off also. It is a Hitachi 60 inch big screen 1997 model
Sounds like you have broken solde joints on the vertical/horizontal board. I have a tip at http://www.fixya.com/support/r4751428-fix_no_vertica_drive_problem which explains the problem and how to fix it. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 12, 2010 | Hitachi 60V500 60" Rear Projection...
Looking for an operating manual for DWX 2880gb Daewoo TV. My mum played with the remote and scrunched the picture down to a band across the middle of the TV and we can't get it reset to a normal picture.
You can do an online search for this. Put
"DWX 2880gb Daewoo" in the search box. This web address should get you what you need.
www.remotesrus.co.uk/remote/make/DAEWOO.htm
Oct 25, 2009 | Televison & Video
I have sound but no picture--just a colored line down one side and the text for the main screen scrunched up into a corner
Sounds like the deflection circuitry has failed. You will need to take the TV to a repair shop (or just buy a new TV). There are "no user serviceable parts inside" so don't try to repair it yourself.
Sep 18, 2009 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Sylvania TV
this is called a "collapsed" picture. it is normally a simple repair for a tv technician. simple for them but almost impossible for the average consumer. if the set is fairly new and not under warranty it might be worth your effort to take it to a tv repair place and get an estimate on the repair cost and go from there. if it is an old set it is time for a new one.
May 03, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Panasonic CT-20G4 TV Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
