Question about GE Refrigerators
Used refrig was laid down in transport from one location to another. Now the unit won't cool..
  • GE Master
  • 3,051 Answers
Hello there
a refrigerator needs to stand up straight for at least 12 hours after it has been laid down if it has been more than i hour to allow the refrigerant to settle back in the accumulator if you just plug it in you have a good chance of destroying the compressor or damaging it
I would recommend first having the unit serviced to see if the refrigerant level is low and if it is this is good get it recharged and than test it out and hopefully it will return itself to it's normal cooling like it did before if not than you know your compressor needs to be repaired ok
I hope that this has been very helpful for you
Best regards Michael
Posted on Nov 17, 2009
My Hisense fridge was transported lying down. After specific instruction to keep upright. Will it be damaged
In most cases no, the reason they don't want them to be laid down when transporting is because they have oil in the refrigerant lines. When the unit is laid down, the oil pools in pipes and can cause issues if the unit is plugged in immediately after being stood up. In order to reduce the chance of something going wrong, allow it to stand up right for 24 hours before you turn it on.
Mar 18, 2018 | Refrigerators
Picked up dehumidifier and transported it to another location. I laid the unit down on it's back. I let it sit overnight before attempting to turn on. Plugged in and the switch clicks but unit does not...
It may simply be the case of the bucket not being reinstalled properly or that the float valve in the bucket is stuck in the up position, from lying on it's back. Turn the unit OFF & unplug it, before checking these 2 things.
Hope this helped you & thanks for choosing FixYa.
Sep 07, 2011 | Maytag M3DH30B2A Dehumidifier
My GE refrig. won't turn cool. control panels are blinking.
replace the main boarde located in the lower rear area of the unit behind a panel new board # G.E. 55x10942
Aug 07, 2011 | Refrigerators
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Need to transport a Toshiba 43vs9ua 43" TV....can it be laid down on its screen or back for 3 hours??? And if so what is the standing period prior to turning it on?
If this is a tube type TV it should be transported the same way as a Plasma type. Upright. The reason for this is because if the screen is not supported in the centre and evenly across the whole area of the surface, it may break being made of glass and heavy. I normally transport them face toward the side of the van and up against 2" of foam rubber with tie down straps to keep it steady.
There is no standing time before use however, if the climate is different to the transport, (air conditioned and cool but warm in the room it is put in), it is adviseable to let it reach the same temperature avoidind problems with condensation. This normally takes a couple of hours.
Hope that helps.
Mar 29, 2011 | Televison & Video
I was told that I should wait 24 hrs before pluging in a refrigator that had been transported lying down. Is this true?
HI,Yes for most refrigerator you do have wait because the oils come out of the compressor so the oil must settle back down.But some refrigerators you do not have to wait if laid on their side, if it was new in box it will say on box "lay this side down" if not better safe then sorry.
Mar 05, 2011 | Jenn-Air JFC2089H Bottom Freezer French...
I just sold my Magic chef refrigerator (20.8 cu ft). It was 2 years old . I plugged it in for the buyer. It got cold as it worked perfectly. the buyer said he was going to lay it down to transport it...
i have been i the appliance service industry for approx. 18 years and everytime i see someone lay a refrigerator down or talk about it i literally cringe.... it can be done and sometimes will work ,but what happens if it does not sit upright and notice i said and all the oil runs back down it will fail everytime.... the oil gets in the evaporator and then will not run correct when the compressor comes on it pushes that oil through system and will clog capillary tubes and or slug unit creating it not to pump properly.... guarantee this is what happened to the unit... if it indeed worked fine before you sold it he either allowed oil to saturate the evap coil or something in the sealed system broke in transport causing freon to leak out...
Jan 26, 2011 | Magic Chef CTB2125 Top Freezer...
A church member donated a freezer to our church, I had to lay in down to transport it. I plugged it in , the light came on but after five days it did not cool ,one bit. Did harm the unit by laying it down?
You pluged it back in after you laid it doun. You needed to let it stand back up to let the freon to get to the condencer. You can try to unplug it for 2 days now to see if the freon will go back down or you might need to have it serviced now.
Good Luck
Aug 14, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
What causes my fridge to run hot? It thinks its an oven! It was working fine prior to transportation, after which it was left for three hour prior to switching on when it ran hot.
I believe it may have been laid down during transport. Leave it unplugged for another 24 hours and allow the compressor oil to return back down to the compressor. This is a very common problem if laid down on side during transport. After this time replug the power cord and listen and feel to insure warm air blows from bottom of refrigerator and cold air in freezer. The oil is to thick and heavy to be pushed through the capillary tube. Just be patient and not try to push the time getting it to cool again as the compressor will continue to overheat if oil remains in the cap tube. Thanks Sea Breeze
Mar 12, 2010 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
