Question about Canon DR-1210C Scanner
We are using the job registration tool with a Canon 2580C on an XP machine. We have multiple users, each with their own roaming id. On installation the tool info is located in the User area of the Registry which means that we need to re-install it for every new login. Is there a way to place the Tool data in the Local Machine Registry area?
  • Canon Master
  • 13,433 Answers
Hi
could you confirm which version of the program you are using, is the program the one available from canon USA support website?
DR-2580C Job Tool Version 2.6 for Windows 2000 SP4, XP SP3, XP 64bit, Vista SP1 and Vista 64bit. (32.9 MB)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11360
Please let me know and I will look into the issue,
thank you,
ekse
Posted on Nov 17, 2009
Scanner only scans top page although set on duplex setting.
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Feb 05, 2010 | Canon DR-2580C Path-Through Scanner
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
How locate and transfer job registration tool data for new installation
There are 2 methods:
1) On the existing PC, start the Job registration tool, click the "Administrators" button (on the bottom of the dialog), then click the "Backup" button in the dialog that appears. This will save a registry file that you can then transfer to the new PC.
2) Use regedit to browse to the
HKEY_CURRENT_USER\SOFTWARE\Canon Electronics Inc.\DR-1210C-JobTool
branch. Save this branch to a file, then transfer it to the new PC.
Cheers!
May 10, 2008 | Canon DR-1210C Scanner
Installation problem
Unistall, disconnect the scanner, power off the comp and reinstall. Check if the comp recognises the scanner.
S. Mohan, Chennai
Apr 09, 2008 | Canon DR-2580C Path-Through Scanner
Name on paper
Depending on the machine, the setting will be in one of two locations, In your menus under either Machine Settings or Fax Settings. You will find the machine ID, That is where you change it.
Mar 13, 2008 | Canon FAX-L900 Plain Paper Laser
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
50 people viewed this question
old marine
old marine
