I have got 4 big circles on my screen with no picture,they are the size of a side plate,it did start of with just two ,but got bigger and they moved down the screen
  • stenikrob Nov 17, 2009
    its a thomson scenium 27lcdb03b
    President:
  • 1,284 Answers
Can you post the make and model number of your TV please for further assistance.
Thank you
Posted on Nov 17, 2009
How do I make my pictures bigger and not pixerlated
if you increase image size, it gets pixelated. there is no way to make it bigger, but not pixelated. except taking a similar photo with a better camera.
Sep 02, 2012 | Dell Computers & Internet
Touched something and my web pages have gone small print managed to start to get it bigger somehow but still not big enough
Try clicking on "view" in the upper right side of your screen - near file and edit. Then slide down to zoom and choose a larger size.
Jul 29, 2011 | Computers & Internet
The picture is too big for the screen. The four buttons will only adjust colour and contrast - not size
To adjust the screen size (resolution) you have to right click on an empty place on Desktop, select Properties and then Settings. Under screen resolution change it to more, until it shows under it 1024x768, or even bigger if you want and it is possible.
Dec 22, 2010 | Packard Bell 15".28 1024x768 Beige CRT -...
Screen Output is bigger than screen size
You can shrink the picture by pushing the menu button on the front of the monitor and scrolling down to the "vertical" and "horizontal" settings and pushing the minus key a number of times until you see the edge of the screen come into view.
Dont forget to save your setting as you exit or the picture will be too big the next time you start your monitor and/or computer.
Good luck and be careful.
Mar 08, 2010 | Acer X193W LCD Monitor
Double halo in picture and writing and all info in a circle type format
replace box in side tv, about a size of a cell phone,may little bigger than that the. cost for the part is about $200.00 or it call the moduler,tv can replace, if you move the tv, make sure u undo the wires 1s ,, why u ask some of these wire don't bend and brakes the box, it cracks,,it ,, that what the picture don't look correct, it looks like a bow and double view
Jan 27, 2010 | RCA P60921 60" Rear Projection Television
How hard is it to change the housing on a k750i thats the chassis and the facias?
Sony Ericsson K750i LCD replacement (below)
If you require a new screen, phone cover and screwdrivers, they can be purchased here: http://www.formymobile.co.uk/proddetail.php?prod=k750ilcd
Tools required: plastic shim such as a guitar plectrum, Phillips screwdriver and T6 screwdriver
  • Remove the battery cover, battery and sim card. Unscrew the 2 x Philips and the 2 x T6 torx screws you see. Use the shim to skim around the edges of the back cover, whilst gently lifting the cover to prise and release the clips (as pictured below).
  • Below is how the phone will look once you have removed the front cover. Now remove the keypad
  • Next, remove the plate below the keypad and black plastic backing. Lever this part gently from the left side of the phone as pictured. You’ll see a connector on the right hand side of the phone (circled). Using a small flat screwdriver, unplug it and lift away the plate.
  • WARNING: There are 2 tiny brass-like clips on the black plastic backing plate (circled). DO NOT lose these! In fact, try not to even dislodge them from the plate.
  • To replace the LCD, remove the 2 x T6 torx screws from the top of the screen. Unplug the screen connector from the PCB (circled in yellow).
  • Then, easing it over the joystick, lift the screen free. Replace with the new screen. Reverse the procedure for disassembly and it's finished.
Nov 24, 2009 | Sony Ericsson K750i Cellular Phone
Blue circle in the center of picture
I need to know what color you got the circle in because one of your lamps went out and needs to be repaired this circle is only going to get bigger an bigger and shall i go on? Easy fix buy the new one and have it put in around $90 bucks plus labor.
May 24, 2009 | Hitachi 46F500 46" Rear Projection...
Picture too big
Assuming that it is not a hardware problem, in Windows XP (or in most Windows version), you need to increase your display screen resolution. To do this, pls click on any clear area of your desktop. Click on Properties, click on the Settings tab, move the Screen resolution slider towards the right. Tha maximum resolution of your Acer LCD is 1280 x 1024. Set it to your preference/allowable. Click on Apply button, click on Yes button, OK.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Acer AL1912 19" LCD Monitor
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
