Question about Nokia 6230i Cellular Phone
Nokia 6230i discharges a fully charged battery (including new replacement battery) in less than 2hrs. Also does not indicate when battery is full even when the charger is disconnected/reconnected and the charge indicator is showing a full charge?
Lax-max blue tooth new generation wireless visor speaker: How do you knlow when it is charged?
If there is no visual indication built in then you won't know but a guesstimate will be found in the operating instructions from the recommended charging time and the time it operates from a full charge.
If the device uses lithium ion batteries it is better to charge little and often rather than wait until they are discharged. The life of lithium ion batteries is shortened by the heating of long charge times and being fully charged - not discharging to less than 30% capacity and not charging to more than 80% will ensure the batteries last longer...
Oct 20, 2017 | Radio Communications
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Fully charged mobile battery discharges half within 2hrs.without use
Did you check with new batteries. If not replace with new one and check how your phone behaves.
Kindly revert back for any further assistance.
Apr 26, 2012 | RIM BlackBerry Pearl Flip 8220 Cellular...
My ibm wont turn on unless the charger is in it just wont turn on.
The battery must have gone bad! if its three or more years old you need to get a new battery for the computer. Periodic conditioning of the battery from first use may prolong the battery life. Battery life is reduced by plugging computer with battery all the time.
Conditioning. Periodic full charge and full discharge practice is good for battery. Batteries are better charged when they are at less than 10% power and its better to charge them to 100%. Do not leave on electric power once they are fully charged.
I hope this helps in future but current battery may need replacement!
Sep 14, 2011 | IBM ThinkPad T40 2373 Notebook
Hi ive got a samsung galaxy s2 and the battery life is really bad. I will charge the phone fully over night and ut wont even last half a day. Is this a commen problem or do u have a dodgy battery
How old is the phone/battery?
Has the battery been fully discharged (used until it will not power up the item) very many times?
This is very bad for Li/Po batteries. If the phone is less than 6-12 months old, I would contact my cell provider and ask for a replacement battery. In lieu of your provider replacing it, your only option will likely be to replace it yourself. Unlike the old-school Ni/Cad rechargeable batteries, Li/Po batteries lose their ability to hold a charge if they are drained fully too many times. Also a good tip with a new battery is to charge it longer than just until the battery power indicator is full (overnight is a good basic rule, but check your phone's user guide or google the specific battery model for recommended charge times) for the first few charges, and avoid letting it fully discharge. Try to get it on a charger with at least 1 or 2 bars left. This will increase the life of a cell phone battery dramatically.
hope this helps,
r
Sep 12, 2011 | Samsung Cell Phones
My battery on the tool bar has got an x on it and says it is fully charged but when put into another laptop it says charging
I understood your problem ,
actually on windows task bar you will see the battery symbol...and as you mentioned in your question that red X on that.
It cause due to the over charging / very less charging of battery...You should charge your laptop for just 2hrs only which is enough time to full charge your laptop..
here as your problem which indicates you need to replace your battery with new one....then test it...and be careful with new battery.
Thanks for giving me opportunity to solve your problem..
please give your Rating!!
Jun 17, 2011 | Acer Aspire One Netbook
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
My nokia 6230i gets power off itself despite my changing Battery? it also runs out of charge very quickly, why?
Sudden discharging of battery indicates that it is time to replace it.If again the problem exists re- install your phones software..
Jun 27, 2009 | Nokia 6230i Cellular Phone
New iPod touch does not fully charge
To fully charge takes about 4hrs. The first 2hrs are a fast charge bringing it to about 80%. The following 2hrs are a trickle charge to bring it to as near to 100% as it can get. It is possible that the iPod hasn't yet calculated what 'Full Charge' is yet based on your devices installed battery. Give it a few days. If it still does this after a few charges and near complete discharges then do a reset. to do this, while it is on press and hold the Menu and Standby/Power buttons for about 10 seconds until the Apple symbol appears. This should get it to do a self test which will re-analyse the battery.
All the best
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
Nokia 6230i Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
