Hi Can anybody help me to get my computer to reconize my new hardrive. I need to format it first as its not been used before. Do I have to go into bios first? if so how do I set the bios up to reconize my second hardrive I do have 2 diffrent types of hardrives one is the old type which I am currently useing and the other is a sata, it is this one that I am having problems with.I am useing MSI Athlon 3000 Motherboard Many thanks Chris
  • 4 more comments
  • lipreader1 Nov 17, 2009
    Hi,Tom I am already running the old drive no problems. I am useing it now and have no problems with it.I installed the new hardrive sometime back but have not had time to get it sorted. I do allot of photography and want to transfer my photos onto it, but need for the system to find it first. If I am correct it is something in the BIOS that you have to do to get it to be reconized. Many thanks Chris
  • lipreader1 Nov 18, 2009
    Hi Steve, ok I have followed as per your instructions and have now got the bios to reconize the disk, it is showing up in disk manager but it is not showing up in my coputer. All that is showing is local disc C which is the one I am using at present. I need it to show me disc D I have checked the volume and the details coming up are disk 0 Basic No volume showing or capacty. can you please advise further Many thanks Chris
  • lipreader1 Nov 19, 2009
    Hi Steve, I have tried the last part of your help and all I get on right click is right or left reading show unicode insert unicode control.Any other suggestions Thanks Chris
  • lipreader1 Nov 24, 2009
    Hi guys thanks for your help. The problem now solved. The problem was in the Bios setup. The sata drive was classed as RAID which should have been IDE. It is now working perfect5. Thanks again. Chris
  • lipreader1 Nov 26, 2009
    Hi The problem was in my BIOS setup. It had found the SATA hardrive but it was classed as a RAID, instead of IDE so I changed it to IDE in the drop down list found in the BIOS setup.I then reboot the system and used SPOTMAU DISK to PARTITION and FORMAT. In fact I have 3 HARDRIVES on my computer and they all work.
  • toomaspai
    toomaspai May 11, 2010
    Hi, SATA drives should in most cases be recognized automatically in BIOS. How do you know that your HDD is not being recognized? It doesn't appear in your OS or you cannot see it in BIOS? I had a somewhat similar problem lately trying to get mb recognize a new SATA drive. In my case it was a bad mb, which had 4 of its condensators swallen - after replacing them, everything worked fine. Tom
    Novelist:
  • 210 Answers
In the days of AMD Athlon chips we didn't have SATA, but it sounds like you do, and you have hooked the drive up?
1) Make sure the BIOS has SATA enabled as well as IDE
2) Make sure your device manager has a driver for your motherboards SATA controller
3) Open computer management
4) Choose Disk management
5) Initialise disk
6) Create partition.
7) Format as per normal.
Posted on Nov 18, 2009
  • 2 more comments
  • Steve Rand
    Steve Rand Nov 18, 2009
    Good stuff! If you are in Disk Manager, you can right-click on the right-hand side where there is no partition, and then create the partition. When you are at the formatting stage, it will ask which drive letter you wish to use.
    A quick format should take 30 seconds, and then the disk will appear!
  • Steve Rand
    Steve Rand Nov 19, 2009
    I think an email with a screenshot would help greatly.
    Unless there is a serious problem, we should be just about done.
    You can get to Disk Manager (control panel, admin tools, computer management), but i've never seen anything about unicode/insert unicode before.
    It *should* list your physical disks on the left, with their associated volumes/partitions on the right.
    Your new disk should be initialised, show as basic, and have 'unallocated' space on the right.
  • Steve Rand
    Steve Rand Nov 22, 2009
    Feedback would be "rockin" ;o)
  • Steve Rand
    Steve Rand Nov 25, 2009
    Ah yes, ideally, it should be AHCI which supports native command queueing and other SATA technology. It will be quicker at that setting, but it will require the SATA controller driver etc that I mentioned previously.
    IDE mode will force the chipset to recognise and use the SATA disk as an IDE disk... which will work, it's just not optimal.
I cannot install the game, cd key is needed, can anybody help how to get a cd key?
if you lost your cd key you have to contact Ubi Soft to get a new one.
If you got the game used then you are probably screwed....the code can only be used one time.
Aug 01, 2010 | Ubi Soft Entertainment Tom Clancy's Ghost...
Computer problem
take caution the SATA HD is Not reconized by Operation system as Installing Booting seq. Need to Change the Bios Setting from HD S*** to IDE. is needed in some computers, and try again
Dec 25, 2009 | Toshiba Satellite P105-S9722 Notebook
When hardrive connected it says found new hardware
You need to format the external drive. Format the drive as primary drive ans in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
Oct 02, 2009 | Acer Computers & Internet
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hardrive not being reconized by computer
There's are a couple of registry patches for Window's users for unrecognized external devices. Install the patches from the links below.
http://support.microsoft.com/kb/925196#fixit4me
http://go.microsoft.com/?linkid=9643528
For the above link, click on the "Fixit" box to install the patch.
Ps3 not formating 500gb internal new hard drive?
Hi Eric,
First you will need to connect the hard drive to your computer or a friends, either using a hard drive enclosure or cable
Then you need to format the drive into fat32 format (full format recommended , not quick format)
Then put it back into your ps3 and have a usb flash drive with the latest ps3 software loaded
then you will be able to format the drive and load the ps3 os
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
RCA Opal Says Boot Error Format Unit.
Then you need to format the memory, If the computer doesn't recognize the device then it is defective.
Jul 25, 2017 | RCA opal MP3 Player
My secondary hardrive was accidentaly reformateed
well depending on what type of format, the content may still be retreivable. What is your computer/OS?
Oct 19, 2007 | Western Digital WDG1C2500N MyBook Premium...
Formatting my WD external hardrive
Hi, In computer terms, formatting a hardrive is the process of preparing/setting the different areas (for read/write) of the harddrive and keeping a list of the addresses. This way the computer would know what data went with what and to where in the HD. Most if not all new HDs are not formatted (prepared) for computer use but are detectable by the PC. Formatting not only makes the HD recognizable, it is now usable. By formatting, the PC also erases any and all references to the existing data on the HD. After being erased and prepared, it also checked for any possible errors. Hope this be of some idea/help. Good luck and kind regards.
Sep 10, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
