Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
"This device cannot find enough free resources that it can use. (Code 12)"
I installed my HVR 1600 in my machine tonight and after powering it back up was reduced to 4bit color and 800x600 resolution.
I checked my device manager and my video card (nvidia 6600gt) had an error stating: hvr 1600 "This device cannot find enough free resources that it can use. (Code 12)"
I thought it might be a compatibility issue with the drivers for my nvidia 6600gt, but after installing several different newer drivers, nothing worked.
After that I tried powering my machine down and booting up with the HVR1600 in different PCI slots each time. That didn't work either.
I am at my wits end and have been working at this for the last couple hours. I am not computer illiterate, but I am also not a computer genius by any means. That being said, if you have any helpful ideas or solutions, please spell them out a little to save yourself the time of clarifying later if I do not understand.
Thank you all for your help.
  • Wombat391 Jan 10, 2008
    Bare-bones computer specs if they help:
    Abit IC7-G mobo
    P4 3.0GHz
    Nvidia 6600gt
    1GB OCZ
    A machine that is just over three years old, but I was hoping to turn it into a PVR since it chokes too much on ProTools these days.
I just had this same problem. Same mobo. Same vid chip. Same TV card.
I resolved the problem by correcting the AGP apature size (256Mb) in the system board BIOS settings.
Posted on Apr 12, 2008
    Genius:
  • 1,601 Answers
Two devices have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or a combination of the two).
You can use Device Manager to determine where the conflict is and disable the conflicting device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Posted on Jan 11, 2008
    Problem Solver:
  • 8 Answers
Ic smoke is right,
I had followed all other ideas, none worked,
I have windows xp, and was changing my old AGP video card (256mb nvidia Geforce 6200 to an AGP nvidia Geforce 6200 512mb)
for details on changing aperture do this:
-Go to BIOS (press Delete key during startup)
-find Aperture settings (for mine I went to Advanced Chipset)
-Adjust Aperture setting from 128 to 256
-Save and Exit (usually F10)
Viola, beautiful Desktop appears!
Posted on May 19, 2011
I had the same problem.. and followed the solution of ic_smoke... solved! thanks!!!
Posted on Aug 04, 2008
Freezes
You may not have enough computer power to run it. Try shutting down some running programs to see if that helps, if that doesn't do it you don't have enough computer power. Those takes a lot memory to run.
Nov 15, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Nvidia geforce 8400 GS pci code 12 error not enough free resources to use (no conflicts)
Error code 12 is one of those errors I hope you won't ever receive, because fixing the problem can be rather difficult. There are two different things that can trigger this error. The most common problem is a resource conflict. Essentially, this means that two hardware devices have been assigned overlapping resources.
A corrupt Multiprocessor System (MPS) table can also cause error code 12. If the MPS table is corrupt, it can cause the BIOS to allocate insufficient resources to hardware devices. I have had a really tough time locating information regarding a solution to this problem. From what I have been able to tell, though, it appears that an MPS table can become corrupt as a result of a damaged hardware abstraction layer (HAL). If that is the case, then reinstalling Windows may fix the problem.
In plain English :D either you have 2 pieces of hardware trying to use the same resources (unlikely), or you have software that is trying to run the same driver twice. I believe that about the only way you are going to get rid of that message is with a clean install. Even then I wouldn't guarantee it.
Jul 17, 2009 | Evga NVIDIA GeForce 8400GS, PCI Express...
Not enough resources to to use AIRCARD 881
Hi there.
Code 12 This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)Cause
This error can occur if two devices that are installed on your computer have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or both). This error message can also appear if the BIOS did not allocate enough resources to the device.
Recommended resolution
You can use the Troubleshooting Wizard in Device Manager to determine where the conflict is, and then disable the conflicting device.
Disable the conflicting device
  1. On the device Properties dialog box, click the General tab.
  2. Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide.
  3. Follow the resolution steps provided by the wizard to resolve the problem.
Good Luck and thanks for choosing FixYa!!
Jun 02, 2009 | Dell Latitude D600 Notebook
Installing a 3rd party nic adapter I code error 12 (Vista) The device cannot find enough free resources, The integrated nic is out and the bios won't find it. Thanks Jack
It sounds like device drivers are conflicting. Erase all network card data from before, and reinstall the new one. Hope that helps. =]
May 21, 2009 | Computers & Internet
Nvidia driver problems
y0ou need to disable one of your pci add-on cards to free up resources.
go to device manager under system, in control panel-classic view.
scroll through your devices and click on the resources tab to see which device is using the memory address/dma/irq ect that your video card is wanting to use.
Mar 29, 2009 | Computers & Internet
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Error code -12
go to control panel>> system>>hardware>> device manager.
double click on the netgear, go to resources tab, if there is conflict (it should). click on "change setting" select the memory range and the IRQ untill you see "no Conflicts" in the lower box.
close and exit. restart the machine.
Sep 06, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Matrox G400/450 installed and Getting error code 12
Is this in addition to or inplace of the existing HD? Do U check the Bios to insure it was reconized by the pc? There should be a cd to boot up on that will preset (fdisk) the HD, did U run that?
Jun 18, 2008 | Computers & Internet
Problem installing WinTV HVR 1600
It just means that it is not not registered to work with windows by microsoft.
The manufacturer doesnt have to work with Microsoft to make their products work.
If possible you can go ahead with the installation. To be safe set a restore point before doing so, though
Jan 12, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
4,988 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
